Results 1 to 22 of 22
  1. #1
    Broken In sam142000's Avatar
    Jul 2012
    Gurgaon
    Default What Laptop configuration better?
    Buying a new Laptop. Which configuration in better?
    3rd Generation Intel® Core™ i7-3612QM Processor (6MB cache, up to 3.1 GHz) with AMD Radeon™ HD 7730M DDR3 2GB
    OR
    3rd Generation Intel® Core™ i5-3210M processor (3M Cache, up to 3.1 GHz) with NVIDIA GeForce GT 650M GDDR5 2GB
    Its a Dell Inspiron Laptop.
  2. #2
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Default Re: What Laptop configuration better?
    What is your Budget ? I will advise you to go for a killer Desktop.
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  3. #3
    Jul 2012
    Gurgaon
    Quote Originally Posted by Sainatarajan View Post
    My budget is 60-70k. I want to buy a laptop only. I know, I can get a killer desktop for this price.
    Dell Inspiron 15R SE: i7-3612M, AMD 7730M 2GB DDR3, 1TB HDD, 8GB RAM
    Philips SPA5300 2.1 Speakers
    CoolerMaster NotePal X-Slim cooling pad
    WD My Passport 1TB portable HDD
    Galaxy S2 XXLPD, Siyah v5.0
  4. #4
    Apr 2012
    What is your purpose ?
  5. #5
    Jul 2012
    Gurgaon
    Wanna play all the latest FPS and Racing games online. Also do some photoshoping.
  6. #6
    Jul 2012
    Gurgaon
    Anyone there??
  7. #7
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    2nd config is better as per your requirements.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  8. #8
    Alpha Geek pranav0091's Avatar
    Jul 2011
    Wherever I am
    Check out the new range of laptops from acer. Digit has reviewed it.
    HP Pavillion dv4 3016tx | i5 2.33GHz | ATI HD6750M 1GB | 4GB RAM | 500GB HDD
    Grado SR60i | Panasonic HJE120 | Soundmagic E10
    Lumia 920 | Nokia N70 | Sony Ericsson Xperia Ray
    Canon EOS 600D 18-55 Kit lens
  9. #9
    Jul 2012
    Gurgaon
    To avoid any confusion see following links
    New! Inspiron 15R Special Edition Laptop Details | Dell India - Costing Rs.58,990
    OR
    Inspiron 17R Special Edition Laptop Details | Dell India - Costing Rs.63,999
    Now tell which one's better.
  10. #10
    Mutant Ninja Swapnil26sps's Avatar
    May 2012
    hostel
    dashing.sujay already said,2nd one is better. And if gaming is primary then better buy a desktop as suggested by sainataranjan. You can do photoshop too.
    zzzzzzzzzzzzzzz
  11. #11
    as Sam Fisher rider's Avatar
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by sam142000 View Post
    OR
    2nd option is much better but weighs 3.4kg, so you face difficulty in mobility.
    Better to go with samsung series 5 550p laptop powered by 3rd gen core-i7, 8GB RAM, GT 650M 2GB, JBL Speakers with sub-woofer and blu-ray drive. For just 56.5k with 2 years free warranty.
    LINK
    Google Nexus 4 16GB running 4.2.2 Jelly Bean | Antutu Score: 17552 | GeekBench 2 Score: 2151 | SoundMAGIC PL11
    hp pavilion dv6-6165tx powered by Intel Core i7-2670QM 2.2Ghz-3.0GHz | Radeon HD 6770M 2GB GDDR5 | 8 GB DDR3 RAM | 750GB HDD | GeekBench Score: 12022 | Windows 8 Pro x64 | 1TB Seagate Backup Plus USB 3.0 HDD | Edifier M3200 Speakers | CoolerMaster Notepal L1 |
  12. #12
    Jul 2012
    Gurgaon
    Are you guys saying 2nd option to be better just on the basis of Graphic card?
    Radeon card is not that far from NVidia card in the rankings!!
    Look: Mobile Graphics Cards - Benchmark List - Notebookcheck.net Tech
    The 2nd option has just 4gb RAM and an i5 processor whereas 1st option has 8gb ram and i7 processor.
    Also I'll not be able to buy extended 2yr warranty with the 2nd option.
  13. #13
    Aug 2011
    ThinkDigit Forum
    Ranking doesn't define gaming performance, the graphic performance of GT 650M is almost 20-25% better than HD 7730M.
    RAM can be extended easily by putting extra, it is as easy as putting USB no issues.. you need to buy an extra exact same type of RAM that is 4 GB DDR3 1600Mhz, it is better, wiser and cheaper option.
  14. #14
    Sony Loverboy randomuser111's Avatar
    Jul 2011
    That Samsung laptop sounds awesome! Amazing specs for the price.
    @OP Why not look at the Samsung model rider suggested ?
  15. #15
    Aug 2011
    ThinkDigit Forum
    The awesome thing is its 300 nit anti-glare LED display of samsung panel.
  16. #16
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Both are good, but I think 1st one will also fulfill your requirements, better go with it as it has got a better processor also but check how much difference is there in the price of both and which one fits in your budget.
    And one thing more, please avoid 17" laptops.
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  17. #17
    Jul 2012
    Gurgaon
    Quote Originally Posted by aroraanant View Post
    Thanks!! I had thought of buying the 1st one only. But the responses here confused me. The price difference is around 3-4k only!!
  18. #18
    Apprentice 50103's Avatar
    Jul 2012
    Dude I too was at the same crossroads.. went with 650mgt as (from what I have heard) GAMING == GPU (If the game is well optimized for pc). Also Nvidia will optimize games for its gpus, so better get an Nvidia .
    So I went ahead and ordered the 17R SE
  19. #19
    Jul 2012
    Gurgaon
    Quote Originally Posted by 50103 View Post
    I've already ordered the 15r SE with i7. The RAM and processor were not to my liking in the 2nd option. Also 17inch laptops aren't easy to carry and there aren't many bags available for it too.
    Btw Nvidia doesnt make any games. They make gpu for games. Isn't it so??
  20. #20
    Nov 2009
    Bhopal
    errr...?!?!
  21. #21
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    welcome to TDF
  22. #22
    Aug 2011
    ThinkDigit Forum
  1. 13-01-2013, 11:53 PM
  2. 03-01-2013, 10:20 PM
  3. 01-12-2012, 04:03 AM
  1. looking for a laptop: plz chk the configuration given
    By sarincv in forum PC Components / Configurations
    Last Post: 01-10-2008, 09:56 PM
  2. Laptop configuration for 60k
    By deviprasad742 in forum PC Components / Configurations
    Last Post: 13-09-2007, 03:27 PM
  3. laptop configuration
    By just_ankit in forum Laptops and Netbooks
    Last Post: 10-08-2007, 08:11 AM
  4. laptop configuration
    Last Post: 10-08-2007, 02:39 AM
  5. Configuration of LapTop
    By SenthilK in forum Laptops and Netbooks
    Last Post: 21-11-2005, 09:03 PM
