Results 1 to 17 of 17
  1. #1
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Default Suggest a basic laptop
    Hi guys. Need an absolute basic laptop. The following are my requirements:
    1) What is your budget?
    19-22k
    2) What size & weight consideration (if any) would you prefer?
    Mainstream; 15" - 16" screen
    3) Are there any brands that you prefer or any you really don't like?
    a. Like: Asus, Toshiba
    b. Dislike: Lennovo
    4) What are the primary tasks will you be performing with this notebook?
    Coding in java, html5 etc. using eclipse and custom sdk's involving open source framework. Should be capable enough to play 1080p mkv,mp4 videos with ease without applying any post processing filters. General tasks, like browsing and spreadsheet. No gaming.
    5) What screen resolution(s) & type (glossy/matte) would you prefer?
    Should be more than 720p and considering this price range, should be 1366x768. Preferably matte.
    6) Anything else you would like to say?
    Purchase will be strictly local.
    Need your help guys. I guess the processor to lookout in this range is the sandybridge based pentium dual core B950/960. But will ivybridge based pentium dualcores launch soon? Will make the purchase asap as i'll probably be moving out to chennai.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  2. #2
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Re: Suggest a basic laptop
    @vicky, at 22k all are 2nd gen Pentium Dual core based laptop. If you can increase budget by 2k more, check this: Asus X54C-SX261D. Should be available for 23-24k locally.
  3. #3
    Aug 2009
    Gotham City
    ^^ Thanks sam. Its got i3 and i guess its hyperthreaded. But won't the apps i mentioned be sufficient in pentium B series?
    Is this extra processing power justified in my usage? I guess both come with hd 3000 graphics.
    I'll check this model for sure. Can you suggest some toshiba models? My dealer is giving me some discounts and other offers with toshiba laptops.
  4. #4
    sam
    sam is offline
    Jan 2010
    Guwahati
    performance will be mostly same but DC doesn't have HD3000 rather only HD Graphics which is most likely HD3000 with some of the EUs disabled and is clocked low. Spending 2k more for i3 doesn't like a bad idea as usually you get 320GB HDD with cheaper models.
  5. #5
    Aug 2009
    Gotham City
    ^^ Ok sam will check this out asap. And what about toshiba?
    And any idea on ivybridge counterparts at this range? They have hd 4000.
  6. #6
    sam
    sam is offline
    Jan 2010
    Guwahati
    Toshiba C640-I4017. Only toshiba with 2nd gen i3 within 25k but doesn't look attractive and the touchpad feels cheap. If you are getting this for 22k, go for it else do check the Asus. Looks matters a bit
    Intel is still refreshing the 2nd gen PDC. And as pentiums are usually binned chips failing to attain frequency for i series, maybe Intel doesn't have enough chips as of now.
  7. #7
    Aug 2009
    Gotham City
    ^^ Sam the guy quoted 25.5k for the asus one. Will check toshiba tomorrow. The asus one looks awesome and even offers usb 3.0. Prices are a bit higher at my place.
  8. #8
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Why dont you buy it from BBSR then. IMO if you bargain a bit quoting online price, I am sure the dealer will consider it for a lower price.
    IMO the Asus one would a better choice as it has 500GB HDD with USB 3.0 port and also runs cooler. Toshiba run hotter next to HP (AFAIK).
    Check here
    My Blog :D
  9. #9
    Aug 2009
    Gotham City
    How about this if available locally ??
  10. #10
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    ^^Difference between Asus X44H-VX025D and Asus X54C-SX261D
    1.x44h lacks full/numeric keyboard
    2.x54c has one unused memory slot while x44h has none so ram cant be added in x44h without removing the one that comes with it.
    3.obviously the screen size
    Rest specs are same.
  11. #11
    Aug 2009
    Gotham City
    ^^ Thanks for comparing mate. Even i knew about the lack of a ram slot but had no idea about the keyboard not being full numeric.
    So x54c is still the first choice.
    @ Sam
    What about trinity laptops from asus mate? Will they appear within this month in india?
    Will they have some models in the 25-26k figure?
  12. #12
    sam
    sam is offline
    Jan 2010
    Guwahati
    Quote Originally Posted by vickybat View Post
    @ Sam
    14" laptops doesn't have numberpad usually.
    budget Trinity laptops will be late for sure. specially one without GPU. keep an eye on Samsung & HP. They should launch first.
  13. #13
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Even I suggest you to opt for X44 or X54.
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  14. #14
    Aug 2009
    Gotham City
    Ok guys planning to increase the budget and might go around 33-34k.
    Is hp pavilion G6 2005 AX a good buy? The dual cards look good and might serve me well as a temporary desktop replacement for everything that includes gaming.
    So guys what should i do? Hp world quoted me a price of 32.8k.
  15. #15
    sam
    sam is offline
    Jan 2010
    Guwahati
    This is the exact reason i am planning same laptop.
    HP World price is usually on the higher side. Try local market. they'll give you a ton of useless accessories though. But sudden increase in budget? From 22k all the way to 32k !!!
  16. #16
    Aug 2009
    Gotham City
    ^^ haha
    Yeah sam had to up my budget as don't want to miss gaming completely when i move out.
    Besides, i won't be in a state to assemble a good desktop immediately there. So i found this through some research as well as from our tdf member base.
    I guess this proves to be a worthy decision in the end and probably will be my first all amd device.
    Nobody will call me a fanboy after this atleast.
  17. #17
    sam
    sam is offline
    Jan 2010
    Guwahati
    no more Intel fanboy
  1. Suggest basic micro-atx HTPC at 15k
    By nithun in forum PC Components / Configurations
    Last Post: 04-08-2012, 02:25 AM
  2. Please suggest a decent gfx laptop + basic 3g mobile combo for 36k
    By Chetan1991 in forum Laptops and Netbooks
    Last Post: 10-04-2011, 07:59 PM
  3. Suggest a basic laptop @30K
    By royal in forum Hardware Q&A
    Last Post: 24-11-2009, 02:23 AM
  4. Suggest a basic phone within 3.5k
    By sinoop_joy in forum Buying Advice
    Last Post: 13-02-2008, 01:04 PM
  5. Suggest a laptop for basic purpose.
    By john_the_ultimate in forum Hardware Q&A
    Last Post: 09-02-2007, 06:19 AM
