Results 1 to 3 of 3
  1. #1
    Jun 2012
    Question need a gaming lappy
    1) What is your budget? (INR or USD)
    65k inr max
    2) What size & weight consideration (if any) would you prefer?
    15inch or more
    3) Are there any brands that you prefer or any you really don't like?
    a. Like: dell, sony
    b. Dislike: Lenovo
    4) What are the primary tasks will you be performing with this notebook?
    Gaming-Battlefield 3, Modern Warfare 3, Crysis 2
    programming, web dev, hd movies
    5) What screen resolution(s) & type (glossy/matte) would you prefer?
    1366*768, i prefer glossy (doesn't matter much to me)
    6) Anything else you would like to say? (eg: local purchase, ASS,matte/glossy finish)
    i'd prefer local purchase instead of ol...
    Also, at a local dealer i'm getting a dell xps 15 with core i5 2nd gen, 6gb ram, 650gb hdd, 2gb graphics at 58000 inr......is it worth it...??..and is it sufficient for my needs..???
  2. #2
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Default Re: need a gaming lappy
    I suggest you to wait and let other brands come with IVB processor based laptops.
    They will be there in few weeks
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  3. #3
    Right Off the Assembly Line n64freak's Avatar
    May 2012
    IIT Kanpur
    So far, I'd say there are few options for you. The HP Dv6 6165 is a good buy, if you manage to find it somewhere. The newer Dv6 doesn't have that great a GPU, while the Inspiron 15 special edition ships with quite a mean GPU. But the best bet for a gaming laptop will be the Dell Inspiron 17" special edition. Wait two days, they will come out with the FHD option, and after buying, you can slot in another RAM for around 1.5k. That should set you up with quite a machine, as the chip is rated as one of the best in it's class. But Dell delivers in only three weeks, so if you want to wait for it, go. It's also got a good sound system, and Dell has good service, from my experience.
  1. Need a gaming lappy for 70K budget
    By akash1988 in forum Laptops and Netbooks
    Last Post: 01-03-2012, 02:36 PM
  2. Acer Aspire 5740G - " Budget gaming lappy "
    By phanisrinivas in forum Reviews
    Last Post: 31-07-2010, 04:35 PM
  3. Gaming lappy around 45k
    By Anish9218 in forum Hardware Q&A
    Last Post: 01-06-2010, 06:44 PM
  4. Gaming lappy with nVidia GeForce 8800
    By Udaya Maurya in forum Graphic cards
    Last Post: 28-10-2008, 03:28 PM
  5. Help needed for a budget gaming lappy!
    By arsenik in forum Mobiles and Tablets
    Last Post: 12-08-2008, 05:14 PM
