Results 1 to 2 of 2
Thread: Buying advice
27-05-2012, 06:46 PM #1
Buying advice
I'm considering buying a laptop, my budget is around 55-60k
So far, I've gone through some sites, and found three laptops which I feel are kinda good.
Can someone help me choose which one to go for, or recommend some others?
I plan on using this laptop almost entirely for gaming, and for watching movies, and to get the occasional studying done
The laptops are:
ASUS Asus K55VM-SX086D:
3rd gen i7 @ 2.3 GHz
6 MB L3
8 GB RAM (DDR3)
1 TB SATA @ 5400 RPM
Nvidia geforce 630M (2 GB DDR3)
HP Pavilion DV6-7010TX:
6MB L3
6GB RAM (DDR3)
640GB SATA @5400 RPM
Nvidia Geforce 630M (2 GB DDR3)
Beats audio
Dell XPS 15:
2nd gen i5 @ 2.50 GHz
8GB RAM (DDR3)
750GB SATA @ 7200 RPM
Nvidia Geforce 540M (2 GB)
Now, as far as the prices are concerned, the ASUS comes at 54k, the HP at 59K and the Dell at 63K.
As far as I'm concerned, it's either the HP or the ASUS for me, as the 3rd gen processors seem to be the deal clincher. The graphics card on the dell is more or less the same as that on the others, and the processor is slower.
But, the thing is, both ASUS and HP aren't really known for their gaming capabilities, and though I've used HP extensively, I have no clue about ASUS and the build quality, as well as the support. Getting an OS for the ASUS won't be a problem, as my college gives out Win7 premium to all the students. So which one should I go for, the ASUS or the HP?
27-05-2012, 08:33 PM #2Pro/An---tagonist xD
- Join Date
- Dec 2009
- Location
- Kolkata
- Posts
- 1,073
Re: Buying advice
Asus K55 review - a thorough test of the Asus K55VM 15.6 inch laptop - YouTube
Watch this. Pretty good review.Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
Buying Advice of buying a Fridge in 17K ?
By Sainatarajan in forum Consumer electronics and everything elseReplies: 0Last Post: 27-05-2012, 09:36 PM -
PC buying advice!!!
By aftablonely786 in forum PC Components / ConfigurationsReplies: 5Last Post: 16-05-2012, 12:32 AM -
PC buying Advice 45k
By dinu630 in forum PC Components / ConfigurationsReplies: 13Last Post: 18-04-2012, 11:25 AM -
Buying Advice
By The Conqueror in forum PC Components / ConfigurationsReplies: 32Last Post: 25-04-2011, 10:21 PM -
Buying advice for cpu in 8k
By soumya.b in forum PC Components / ConfigurationsReplies: 8Last Post: 13-04-2011, 08:01 AM
LinkBack URL
About LinkBacks
