Results 1 to 23 of 23
  1. #1
    May 2012
    Question same graphics card; does processor matter a lot for gaming?
    hi,
    i searched this forum and while i got quite a lot of information about the models i'm confused about, didn't find a definitive answer that'll make me finalize one, hence starting this thread. kindly help me
    i wish to purchase a new laptop, and gaming is a priority for me. i would like to play all the latest popular games (like Battlefield 3, Modern Warfare 3, etc.) without lowering the quality much. the laptop that i have (almost) selected is Asus K53SM-SX010D (i5, Nvidia GeForce GT 630M). my question is that should i go for a more expensive i7 model (with the same graphics processor), or will the one i've chose do? both have same graphics card, but one has i5 and the other has i7. price difference is about Rs.10,000. i don't want to spend the additional money but don't wanna regret buying a low performing laptop either.
    so please help. i really appreciate it. thanks.
  2. #2
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Default Re: same graphics card; does processor matter a lot for gaming?
    Not really. MW3 doesn't need so much of fire power. The i5 based one will suffice
    Also whats your maximum budget?
  3. #3
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    If your sole purpose is gaming, i5 will be enough for you.
    See it works like every component is a system should be balanced. If you pair a high end GPU with a comparatively slow GPU, then of course the GPU will be bottlenecked, so the performance will differ. Similarly, a very fast CPU coupled with a mediocre is gonna do no good except raw CPU power lying useless.
    Performance difference in games also depends upon its nature to utilise certain hardware, i.e, if the games is more CPU dependent or GPU dependent.
    Now you should know your answer.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  4. #4
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    Its not like, anything is more important, as the above post stated, everything should be balanced, if a component is not good enough, it will bottelneck the other, so my reccomendation goes with the i5 RiG as its not such a bad processor though, I don't think you will even ever need the full potential of your i5, its a super processor at its range.
    I am not against i7, but it is not that much for you.
    Hope you got it..
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
  5. #5
    Arsenal Fan arsenalfan001's Avatar
    Mar 2009
    Kolkata
    Quote Originally Posted by koolent View Post
    Hope you got it..
    Perfect.
    If gaming is only requirement, even i3 will also suffice.
    i5 = i3 + turbo boost (for laptops)
    Laptop: HP DV6 - 6140tx | i7-2630 | 8GB DDR3 | 500GB 5400rpm | 1GB DDR5 ATI 6770 | Cooler Master Ergostand
    Desktop: i5-3570K | CM Hyper 212 Evo | P8Z77M-Pro | Sapphire HD 7970 Vapor-x | G-skill Ripjaws 8GB | WDC 500GB | Corsair GS 600 | Corsair Carbide 400R | Microsoft Sidewinder X4 | Logitech G400 | CPUZ | GPUZ | Looking to sell my Note 2
  6. #6
    Oct 2010
    Quote Originally Posted by arsenalfan001 View Post
    Perfect.
    It depeds upon which variant of i5 are you talking about. i5 is much better than i3 but high end i3 might reach low end i5 because only GHz/frequency doesn't matter..
    Well, good question it is.. Many people don't know this.
  7. #7
    Nov 2009
    Bhopal
    From my experience i3 and i5 are worlds apart in performance (in laptops, as said).
  8. #8
    May 2012
    thank you so much guys for the replies. no confusion anymore, i'm going with the i5 one
  9. #9
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Core i3-23xxM, Core i5-2xxM and Core i7-26xxM. All have 2 hyper-threaded cores. 2 Cores and 4 Threads.
    Only difference between them is their base frequency and turbo frequencies. Core i3-2xxxM doesn't have Turbo.
    For "gaming" considering the kind of GPUs paired up with laptops (GT 540M, GT 630M, HD 6490M), Core i3-2330M is the minimum. You're better off saving money if "gaming" is the "only" priority and you're getting the GPUs I mentioned.
    From a jump from i3-2350M to i5-2410M, we're talking about only ~15% difference. From a jump from i3-2350 to i5-2520M, we're talking about ~26% difference. Only in CPU performance/tasks. It is only coming from the frequency/turbo. That's not worlds apart. They are the same die afterall - only binned to differentiate.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  10. #10
    Nov 2009
    Bhopal
    Quote Originally Posted by ico View Post
    i7-2xxxQM has 4 cores.
    Not this. 6630M would have suited there.
  11. #11
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Quote Originally Posted by dashing.sujay View Post
    i7-2xxxM has 4 cores.
    Wrong. I have mentioned i7-26xxM. It has 2 Cores and 4 Threads. Only those which have QM as the suffix - i7-26xxQM and i7-27xxQM have 4 cores.
    HD 6630M, HD 6550M etc. Basically all mid-end laptop GPUs having DDR3 memory was the point. Mentioned HD 6490M as it has GDDR5 memory and people think it is fast ignoring it has only 160 shaders.
  12. #12
    Nov 2009
    Bhopal
    Sorry, I missed the Q part, though there's only one variant 2640M which I have never seen.
  13. #13
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    ya, I think I have seen it in only one model Macbook Pro.
  14. #14
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Obviously it will matter a lot.
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  15. #15
    May 2012
    hi
    i didn't purchase the laptop then, postponed it by a month and turns out now i can spend some extra thousands on it. so kindly answer this follow-up question of mine. can somebody please suggest me a laptop around Rs.50000 range (not more than 51000) that will be better in terms of gaming than the Asus K53SM-SX010D? should i go for the i7 one, or go for a better GPU? specific model suggestions would be much appreciated.
    thanks a lot
  16. #16
    Nov 2009
    Bhopal
    ^No, i7 won't help you much in gaming. Consider getting a better GPU which is sadly not available in your budget (or even in 55k).
  17. #17
    Jun 2011
    Roorkee
    ^^ Completely agree with that.
    Still the Asus K53SM-SX010D is probably the best option for you, and you save money!
    But if you want to spend, & since only gaming is your priority, if you don't care much about portability go for a desktop It's just my opinion.
  18. #18
    Wise Old Owl NoasArcAngel's Avatar
    May 2008
    Unknown
    there are some games which are cpu heavy like battlefield 3 .so i guess it is always better to have a strong processor.
    Steam : noasarcangel
    Steelseries : Winning Is Everything.
  19. #19
    In The Zone Prongs298's Avatar
    May 2009
    yes there are some games which are as much cpu dependent as they are on the gfx card. but i think it has more to do with the clock speed than the no. of cores as an i3 at 2ghz will be better for gaming than a quad i7 at 1.2ghz. but some games do benefit from the extra cores. so its better to find a balance.
    There is a stage of worship which makes the worshipper himself an object of reverence.
    Dv6 6121tx | i7 2630 | 6770m
    HP Pavilion dv6 6121tx review
  20. #20
    May 2012
    thanks a lot for the help guys!
  21. #21
    JERK pranavgautam67's Avatar
    Apr 2012
    New Delhi
    anything more.
    Man, i love You Ico, u have some great knowledge to spread.
    U should make a big thread consisting all about processors starting from core 2 duo...
    Best members from now 1-Ico 2- dashing.sujay
  22. #22
    Oct 2010
    Don't worry man.. He will never reply or put a word on what you said. Attitude you know..
  23. #23
    Jun 2012
    Yes even though you have high end graphic card processor matters in loading your game because your processor must support to the graphics.
  1. Processor and MoBo and Graphics Card
    By psagar10 in forum PC Components / Configurations
    Last Post: 03-01-2012, 06:26 PM
  2. Effect of Processor with graphics card for gaming
    By binay00713 in forum Graphic cards
    Last Post: 09-05-2011, 07:37 AM
  3. Processor Vs Graphics card
    By visor619 in forum Graphic cards
    Last Post: 28-07-2008, 04:44 PM
  4. Which Processor & Graphics Card Should I Buy.
    By ASH_DSG in forum Graphic cards
    Last Post: 20-01-2008, 10:40 PM
  5. confused on processor vs graphics card
    By windchimes in forum Graphic cards
    Last Post: 28-10-2006, 09:23 AM
