Page 1 of 3 1 2 3 LastLast
Results 1 to 30 of 62
  1. #1
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Default Sony Vaio CB35 Discussion thread.
    Hello Guys, I have seen multitude of users creating similar threads asking help on CB35. Plus I got countless no of PMs regarding the same. So, I thought its better to discuss everything at one place which will be gradually benefit other members too. Please pour in your any queries, suggestions & problems, if any.
    PS: It'd be better if you can please have a look over my review Sony Vaio CB35 Review. It may help clearing your doubts, if any.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  2. #2
    Master troll red dragon's Avatar
    Jan 2009
    I have few queries mate.
    How is the viewing angle?
    How good/bad is the touch pad?
    Can you ditch your usb/bt mouse even for prolonged work on photoshop?
    How many ext. display does it support?
    Is there any physical button for gfx switch?
    Sorry,actually asked a lot of questions!
    Macbook Air 11"2011,Iphone 4S 16GB,Ipad2,Sennheiser HD-25 1-II,HD650,FiiO(E11,E17...yeh! I know!I need an upgrade)
  3. #3
    Nov 2009
    Bhopal
    Default re: Sony Vaio CB35 Discussion thread.
    Quote Originally Posted by red dragon View Post
    1. How is the viewing angle?
    One word, awesome. While playing a 1080p video at 4/15 brightness, I couldn't notice any difference in viewing till approx 85° (from straight), but 80° can be said as the sweet spot. Also, a drop in viewing angle can be seen as the quality of video is lowered, not much noticeable though. Overall - 9.5/10
    2. How good/bad is the touch pad?
    This is the point which I feel Sony needs to improve on. Its too smooth to handle. If your hands are smooth, then it will work butter smooth as capacitive touch screen, but hands with even a smallest bit of moisture will make it sluggish. Gesture controls are very good though. Score - 7.5/10
    3. Can you ditch your usb/bt mouse even for prolonged work on photoshop?
    Not at all. For me nothing can beat a mouse. I'm also saying in regard to quality of touchpads I have used till date. Have listened a lot about touchpad of MBP though, still got to use it. (haven't even seen a mac )
    4. How many ext. display does it support?
    I guess you're referring to display ports. 1 HDMI + 1 VGA. If you're talking about multiple displays, I guess its 3, including laptop itself. Not sure though, saw in "win+P" menu.
    5. Is there any physical button for gfx switch?
    No, only for WLAN. Hardware switching is available only in S series AFAIK, which cost totally irrational.
    Its all my pleasure sir
  4. #4
    Jan 2009
    Thanks a lot Sujay.
  5. #5
    Sony Loverboy randomuser111's Avatar
    Jul 2011
    Having used both MBP and the CB35 touchpad, I can tell you that its not even close and at least I would personally not be happy if I had use the CB35 for long periods without a mouse. They keyboard is really nice and almost up there with the MBP but the touchpad is nowhere near as large and as smooth and responsive as the MBP.
    Relative to the MBP
    CB touchpad - 6.5/10
  6. #6
    Jan 2009
    That 6.5/10 for a Windows laptop is pretty good.
    The thinkpad or latitude touchpad is so damn annoying!
    @sujay,did you get any driver cd with it?
    Have you installed Ubuntu or something like that?
    Do you know of any 13inch vaio with 1080p screen within 70k?
  7. #7
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    ^^I think there is no Sony VAIO 13'' with 1080P display.1600X900 display is available though.Check this out.It has killer looks.
    VPCSA35GG : S Series : VAIO Laptop & Computer : Sony India
    Buy Sony VAIO S Series Laptop VPCSA35GG (Brown) at Best Price in India - Also find Specifications, Photos, Features & Reviews
    Weight-1.6kg only
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  8. #8
    Dec 2011
    From Manchester but currently working and living in Noida.
    How good is a 1080p screen on a 15.6" screen? I've always thought the text would be quite small on that small a screen? Is it comfortable for general day-to-day use?
    I was considering trying to upgrade the screen on my laptop (if it's actually possible!) because it would help me with my work, but I didn't want to sacrifice readability for it.
  9. #9
    Nov 2009
    Bhopal
    Quote Originally Posted by randomuser111 View Post
    Relative to the MBP
    I haven't used a MBP thats why I gave 7.5. But I feel its still far better then other laptops out there.
    Sadly Sony doesn't provides physical disk. But recovery partition does its work so well. I must say its lot better than carrying a 7 disk. You'll be getting driver setups in C: by default which you can copy and backup. Though one thing I found irritating is that to create recovery media, it asks for a whopping 12 GB space! Or 3 single layer DVDs IDK what it installs in 12GB.
    AFAIK there is no 13 inch laptop with 1080p display, but do you really need 1080p on a 13 inch ? It will be too dense in IMO. 1600*900 will be more than enough. The S series model TeniDa mentioned (which I already mentioned in my 2nd post) is one of a piece I like above MBP. Its the only piece which I feel is above MBP in aesthetics. But its too costly to justify its tag.
    Quote Originally Posted by swooosh32 View Post
    You'll have to increase DPI settings to increase size of text. They're of course a bit smaller than 720p but still a lot readable.
  10. #10
    Jul 2011
    @RedDragon
    As already mentioned above, there is no 13 inch VAIO with 1080p screen. The SA35 is a great machine but even though it has 1600x900 resolution screen I must warn you that the screen on it is strictly average at best. In fact its roughly the same quality as the 1366x768 screen on the SB models. Both are a far cry from the super glossy but still good quality MBP13 screen.
    Since you showed some interest in the CB, I would instead recommend you take a look at the Vaio SE17GG. It is a 15.5 inch notebook but weighs just 1.98kg. And comes with a Full HD IPS screen with great viewing angles both vertically and horizontally. Notebookcheck rated its screen with a score of 94%. This is the highest display score they have given this year to any notebook and this score is higher than any MBP reviewed (MBP 17 scored 86% I believe and the CB scored 84%) The screen has a high contrast ratio too ~ 750:1
    It also comes with a dedicated hardware Graphics Switch button. Also with the extended sheet battery it has a battery life of 10 hours.
    And both CB and SE/SA/SB support only one monitor at a time. Both the HDMI and VGA output cannot be used simultaneously. There is a workaround though. You could try using Display link USB solution.
  11. #11
    Nov 2009
    Bhopal
    Why doesn't Sony takes a leap from 6630M
  12. #12
    Jul 2011
    Quote Originally Posted by dashing.sujay View Post
    The reason behind that is the VAIO line does not target hardcore gamers, especially the C series. Its an everyday notebook that is aimed at people who want to use their PCs to perform daily tasks and for multimedia consumption with some light gaming.
    And the reason why Sony uses the 6630M across a range of models is that it has a nice balance between performance and price, and at the same time plays well with the thermal design as it does not generate a lot of heat. Using a more powerful GPU like the 6770M is not feasible due to the higher heat dissipation.
  13. #13
    Nov 2009
    Bhopal
    6650M could have been appreciated. Not a single model has med-high gfx.
  14. #14
    Jul 2011
    6650M level performance can be achieved easily with a mild overclock
  15. #15
    Nov 2009
    Bhopal
    ^Yeah, but the difference is significantly 120Mhz. Heating issues can't be ignored. Moreover, a factory OC'ed gfx card is preferred any day over custom OC'ing.
  16. #16
    Jan 2009
    Thanks a lot guys for your valuable inputs.
    I have to find something under 14 inch.
    No matter how light,I just cannot imagine carrying a 15 inch laptop(actually I have to travel A LOT)
    Any smaller laptop with an ips display?
    Sorry for going o.t.
    Do not bother replying here,a pm will be nice.
    Thanks again.
  17. #17
    Nov 2009
    Bhopal
    @RedDragon
    I can't find review of CB35 on notebookcheck. Link please? And whats the source of info of no of display?
    Also, if no of simultaneous display is restricted to 1, then why its showing like this? (see pic, duplicate & extend)
  18. #18
    Jul 2011
    Let me explain those.
    Computer Only - Self explanatory. Only the laptop monitor active
    Duplicate - You see the same image on both the laptop screen as well as the external monitor
    Extend - Both the laptop and external monitor are used as one single monitor allowing you to use both the screens together as an extended desktop giving you greater screen real estate to play with.
    Projector Only - Again, self explanatory. When connected to a projector the laptop screen goes blank.
    You can confirm it with Sony support if you don't believe my words All Sony Vaio notebooks with HDMI AND VGA cannot use both simultaneously. Only the Vaio Z2 with Power Media Dock supports 3 monitors - 1 from the notebook itself and 2 from the PMD.
    Link to CB review
    http://www.notebookcheck.net/Review-...k.59604.0.html
  19. #19
    Nov 2009
    Bhopal
    Thnx foe the info, btw the link of review you posted is of a model almost similar to CB35, but not CB35. Changes, 7200 HDD, BluRay. Still its a decent comparison. Apart from it, IDK how they got less battery back up (3hr58min with WLAN off). I get 4 hrs and 30 mins with WLAN on.
  20. #20
    In The Zone Prongs298's Avatar
    May 2009
    @sujay - how are your hinges??
    There is a stage of worship which makes the worshipper himself an object of reverence.
    Dv6 6121tx | i7 2630 | 6770m
    HP Pavilion dv6 6121tx review
  21. #21
    Nov 2009
    Bhopal
    Quote Originally Posted by Prongs298 View Post
    Hinges are all perfect except for one I mentioned in my review. But its too minor to be noticed. Even the notebookcheck guys didn't noticed it.
  22. #22
    Alpha Geek Niilesh's Avatar
    Apr 2011
    Jaipur
    Default Re: Sony Vaio CB35 Discussion thread.
    In This review It is mentioned that CB15 suffers Heating issue
    What's your take on it?
  23. #23
    Nov 2009
    Bhopal
    My take- Observe the following screenshot-
    Now, see the Up time which is 3hr+ and temp is 47°-48°. I must mention that laptop is running by kepping on bed which further obstructs cooling & increases temp. If after this much temp is just this much, can you see any point of heating issues? My lappi daily runs for at least 16 hrs and has never crossed 51°. There is not at all any heating issues mate.
    Moreover I feel blow of "hot-air" only and only when I game, then temps are in sixties or early seventies after prolonged gaming.
    I hope this clears all your confusion.
  24. #24
    Apr 2011
    Jaipur
    It does
  25. #25
    Jul 2011
    Woah!
    CB45 model out, priced at 59990!!!!
    I dunno what else to write here. Sony just blew it.!
  26. #26
    Nov 2009
    Bhopal
    Woah!
    CB45 is just an overpriced CB35 with only 1 change. 500GB.7200 Vs 640GB.5400 . Now, at least for me, the prior wins hands down, may be the shooting sales of CB35 made Sony greedy
  27. #27
    Jul 2011
    What I meant to say was they are going to hurt their sales with this Rs.5000 price hike. CB was a good buy cuz you could get a Full HD screen laptop with decent specs for just about 51-52k. At 59k I am not so sure why someone would choose it over the Dell XPS 15 and HP DV6 and the new Asus models.
    IMO it does not deserve that price with only a dual core CPU and 6630M GPU.
    Thankfully the street price will be about 56k. So its not THAT bad a price but still it should have remained the same.
  28. #28
    Alpha Geek Terabyte's Avatar
    Jun 2010
    Mumbai
    Hey Sujay I am also looking to get this laptop.
    Had one query - Is it possible to turn off the backlit for keyboard? If yes how?
    AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Sapphire HD7850 2GB GDDR5 ||Corsair 4GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
    XPERIA U (Stock ICS) (Rooted)
  29. #29
    Jul 2011
    Yes you can turn off the backlight by going into the Vaio Control Center - Keyboard. You can choose from auto, always on and never.
  30. #30
    Phoenix's Soul swiftshashi's Avatar
    Jun 2011
    Ranchi
    My friend has bought a black coloured CB35 model.After about 1 month of troublefree usage,he's been facing issues with the OS.After every 5-6 days,a message comes "OS NOT FOUND".We hAve tried recovering the system 7times,but the same thing happens everytime.My other roommate with an E series vaio has also started facing the same issue from the pAst two days.
    Can someone help on this??We are really fed up of this and the irresponsible behaviour of Sony support team.
    Laptop-HP Pavilion dv6 6121tx_Core i7 2630QM_12GB RAM_640GB HDD_2 GB DDR5 6770M Graphics at 900/1040Mhz@1.1V _3yrs Warranty.
    SmartPhone-Samsung Galaxy S3 16 GB
  1. Sony Vaio CB35 Unboxing and Review.
    By dashing.sujay in forum Reviews
    Last Post: 20-06-2012, 08:56 PM
  2. Sony vaio CB35 1080p vs Dell XPS 15 FHD B+RGLED 1080p
    By siddharth.saiyan343 in forum Laptops and Netbooks
    Last Post: 12-02-2012, 04:46 PM
  3. Vaio CB35 or HP dv6 6165tx
    By vickyrathore in forum Laptops and Netbooks
    Last Post: 01-02-2012, 09:59 PM
  4. urgently need buying tips on vaio cb35
    By arjoonpk in forum Laptops and Netbooks
    Last Post: 26-10-2011, 08:33 PM
  5. Sony vaio discussion/owners thread
    By ss max in forum Laptops and Netbooks
    Last Post: 24-08-2011, 08:32 PM
