Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 31 to 60 of 62
  1. #31
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Default Re: Sony Vaio CB35 Discussion thread.
    Where are you seeing the error?
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  2. #32
    Phoenix's Soul swiftshashi's Avatar
    Jun 2011
    Ranchi
    thanks for the prompt reply..
    The error is generated just after the vaio logo(bios)
    Laptop-HP Pavilion dv6 6121tx_Core i7 2630QM_12GB RAM_640GB HDD_2 GB DDR5 6770M Graphics at 900/1040Mhz@1.1V _3yrs Warranty.
    SmartPhone-Samsung Galaxy S3 16 GB
  3. #33
    Nov 2009
    Bhopal
    ^Most probably your vaio recovery partition is corrupted. I have 3 vaios with me and never saw this problem. But I saw one guy at service centre with corrupt recovery partition issue, though his problem was something different. You'll have to take it to service centre.
  4. #34
    Jun 2011
    Ranchi
    Can this issue,by any far probability be related to kaput CMOS battery!??Because a similar issue on hp laptop was solved by replacing the cmos
  5. #35
    Nov 2009
    Bhopal
    ^I don't think so. Sounds illogical. But tell me, when you do recovery after you face the issue, does the problem re-occurs instantly or again after a week?
  6. #36
    Jun 2011
    Ranchi
    no,always after a week or so..but for the last time,it occured after a day.
  7. #37
    Nov 2009
    Bhopal
    Hmm.. I guess there's some locha in recovery partition itself. But corrupting again and again sounds like . Rare chances of some rootkit sitting inside recovery. I'd still suggest you to visit sony centre and get you HDD factory restored (mention recovery partition sepcifically).
  8. #38
    Feb 2012
    hi, i have purchased d same cb35 just 15 days back. i gt to say your review of it ws quite helpful. i m havin jus one problem since past couple of days. my keyboard backlight has been kept on auto. in the beginning it used to turn on whenever the ambience lighting ws low (say suppose i switched off a light in the room, it wud turn on). Bt nowadays its been turning on only wen i press a key. i m thinkin mayb theres a problm wid its light sensor??
  9. #39
    Nov 2009
    Bhopal
    Quote Originally Posted by anakin View Post
    Thanks for appreciation.
    Light sensor should be just opposite to light to sense properly. But IIRC backlit never turns on automatically if I shut light off. Its for display light. But I'll try and report back tomorrow. (my laptop is messed up now).
  10. #40
    Alpha Geek Terabyte's Avatar
    Jun 2010
    Mumbai
    Quote Originally Posted by randomuser111 View Post
    Yes you can turn off the backlight by going into the Vaio Control Center - Keyboard. You can choose from auto, always on and never.
    Sorry for the late reply, n thanks!
    Also are you guys satisfied with performance of second gen i5 or getting Quad i7 is worth?
    How is the performance of 6630M? Anyone played games on it?
    AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Sapphire HD7850 2GB GDDR5 ||Corsair 4GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
    XPERIA U (Stock ICS) (Rooted)
  11. #41
    Nov 2011
    NCR
    6630m review:
    AMD Radeon HD 6630M - Notebookcheck.net Tech
    i7 quad core in laptop is worth only for those who use their laptops for serious video editing/encoding,virtual machines/environments,3d rendering etc.for most i7 just means more temp(especially in indian summer)& battery consumption.
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  12. #42
    Jun 2010
    Mumbai
    Quote Originally Posted by whitestar_999
    Thanks but I had already checked that.
    Just wanted to know your gaming experience.
    Ok, so will the two cores suffice for next 2-3 years?
  13. #43
    Nov 2009
    Bhopal
    Quote Originally Posted by Terabyte View Post
    Everything depends on what you exactly use? For instance which games, at what settings. Throw some light on your uses, then it'll be helpful for us to suggest you in a better way.
  14. #44
    Jun 2010
    Mumbai
    Quote Originally Posted by dashing.sujay View Post
    Games like NFS n Dirt series will do for me.
    Laptop will mostly be used for Visual Studio, Oracle, Dreamweaver(i.e. basically all kinds of coding) and other things like browsing and movies.
  15. #45
    Nov 2011
    NCR
    an i5 mobile(2 real cores+2 virtual cores along with turbo boost)should be enough for your usages for next 3 years.according to notebookcheck review 6630M is enough to play dirt3 & should be able to play NFS Shift at low/med settings.i am not a gamer so wait for others but i think NFS shift is graphic intensive game & 6630M will not be able to handle Shift 2 even at low settings.for a good gaming experience on a 1366*768 laptop i think a GT540M or radeon equivalent is the recommended option.
  16. #46
    Jun 2010
    Mumbai
    Guys so should I finalize this laptop?
    Also how is the Sony service compared to Dell?
    Please reply ASAP!! Thanks!
    Edit: Also can we extend our warranty? If yes for how many years?
  17. #47
    Nov 2009
    Bhopal
    Yes, go for it. Its a very good laptop. Sony's service is also good.
    And yeah, you can get the warranty extended for another two year at just 2500/- only, which is the cheapest in the world . I have already got it.
  18. #48
    Nov 2009
    Bhopal
    ^Sony support? Good to see here
    Now give TDF guys some mouth watering deals
  19. #49
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    He sujay you stole my words, I was gonna say the same thing....
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  20. #50
    Jun 2010
    Mumbai
    Great!
    Thanks a lot.
  21. #51
    Apprentice gulati.ishank's Avatar
    Feb 2012
    Faridabad
    @Sujay
    I am soon going 2 buy a laptop as soonas i get into college(a couple months maybe).Can u suggest me which would be better b/w Sony CB35 and asus K53SV.I primarily need it for gaming(Mass effect series ,skyrim ,COD etc).
    Asus has better processor, more ram but does'nt have a backlit keyboard and full hd screen like sony and i don't know which one's gpu is better , asus has GT540M.
    I am really confused.
  22. #52
    Nov 2009
    Bhopal
    540M is slightly better than 6630M (appx 10-15%). If your priority is just "gaming", then of course laptop with better config will win (which k53 has). Regarding backlit keyboard, its bling bling factor, if it lures you go for it, its totally worthy. It totally makes your laptop different from crowd.
    1080p display is something which you won't regret if you can go for it. It just makes everything so beautiful with a bit sacrifice on GPU.
    So, set your priorities and get one. And CB35 is very less in market these days. It'd be very hard for you to grab one.
  23. #53
    Mar 2011
    Aligarh>>>Delhi
    The GPU of Asus is better but all over sony one is much better.
    The display of Asus is not that impressive, that is the major drawback of that laptop and many people have posted about it.
  24. #54
    Feb 2012
    Faridabad
    Is there any better alternative upto 50K.
  25. #55
    Nov 2009
    Bhopal
    No, not even after you add 5k.
  26. #56
    Feb 2012
    Faridabad
    Well,thank you sujay and aroraanant for your advice.
  27. #57
    LoSt! reddead's Avatar
    Feb 2011
    temperatures are 50+ for me even in idle or when downloading something.,it even reached 76 on BF3....
    i guess its because of keeping mine ON all day long
    i am thinking of getting a cooling pad....
    \cooler-master-notepal-l1-cooling-pad\
    hows this one for cb35??
  28. #58
    Nov 2009
    Bhopal
    Can't say. But my temps are around 48-49 and after gaming 3hrs of TF2 it is around 65°.
    And why its not showing HDD temp ?
  29. #59
    Feb 2011
    is it supposed to show HDD temp too?
  30. #60
    Nov 2009
    Bhopal
    The TOSHIBA is HDD in HWmonitor.
  1. Sony Vaio CB35 Unboxing and Review.
    By dashing.sujay in forum Reviews
    Last Post: 20-06-2012, 08:56 PM
  2. Sony vaio CB35 1080p vs Dell XPS 15 FHD B+RGLED 1080p
    By siddharth.saiyan343 in forum Laptops and Netbooks
    Last Post: 12-02-2012, 04:46 PM
  3. Vaio CB35 or HP dv6 6165tx
    By vickyrathore in forum Laptops and Netbooks
    Last Post: 01-02-2012, 09:59 PM
  4. urgently need buying tips on vaio cb35
    By arjoonpk in forum Laptops and Netbooks
    Last Post: 26-10-2011, 08:33 PM
  5. Sony vaio discussion/owners thread
    By ss max in forum Laptops and Netbooks
    Last Post: 24-08-2011, 08:32 PM
