Results 1 to 9 of 9
07-08-2011, 12:15 PM #1Right Off the Assembly Line
- Join Date
- Aug 2011
- Posts
- 4
reinstalling from internal hard disk
I have a laptop HP Pavilion dv2000 with original XP operative system. Though i experimentally tried vista and now is in win 7 I want to reinstall the original XP from its hard drive. I do not see any choice for reinstalling the OS from the hard disk in the booting scren though I remember restoring the OS once without the restore disks. Can anybody tell me which key or key combination allows me to reinstall the OS fron the Hard disk,
SHarK
In continuation of my previous post: After installing windows 7, the f11 key no more starts the recovery screen, and I could not access the recovery partition to boot from.
SHarK
07-08-2011, 12:59 PM #2
Re: reinstalling from internal hard disk
Do you have proper files in that HDD? or is it only plainly installed?
Use a Original Windows CD/DVD preferably to install WindowsFollow me on Twitter: http://twitter.com/wuodland
Have a look at my Photography page: http://bit.ly/N2aMTi
07-08-2011, 03:48 PM #3Right Off the Assembly Line
- Join Date
- Aug 2011
- Posts
- 4
All original files that came along with the laptop PC are there. Earler I had used them also .Mostly the boot manager of Win7 corrupted the function of f 11 key
07-08-2011, 06:37 PM #4
you will have to reinstall everything.
if you have installed vista/win7 over xp, then the xp partition is unrecoverable, due to incompatiblity between the bootladers of xp and vista/win7.
i'd advise to backup all important docs and settings and reinstalling the desired os.Mmmphh-mphhhh-mmphh mhh!!!
07-08-2011, 08:42 PM #5
You have to reinstal xp from your cd.
07-08-2011, 11:54 PM #6
Use HP's recovery/restore disc.
AMD FX 6300 | Asus M5A97 Evo R2.0 | Saophire HD 7870 Ghz Edition | Dell S2204L | WD Blue 1TB | Kingston HyperX Blu 4GB | Seasonic S12ii 520W | Samsung 24x DVDRW | Corsair 200R | Dell Keyboard | Logitech MX518 | Edifer X600 | Microtek 1kVA UPS
08-08-2011, 01:20 AM #7
If the laptop is powerful enough use 7 OR install XP from scratch after backing all data. Any shortcuts will give headaches in the future.
AMD Phenom II 560-Gigabyte GA78LMT USB3-Corsair Vengeance 4GB DDR3-ASUS Xonar DX-1250GB-DELL SP2208WFP-VX450-Corsair Carbide 400R
09-08-2011, 03:36 PM #8
There is actually no short cut.
Macbook Air 11"2011,Iphone 4S 16GB,Ipad2,Sennheiser HD-25 1-II,HD650,FiiO(E11,E17...yeh! I know!I need an upgrade)
09-08-2011, 03:46 PM #9
if i m not wrong then OP has Recovery partition of XP & used to recover it using F11..but
installation of Win 7/Vista corrupted the F11 option to recover.
@OP: do u have the Recovery CD of the XP? u have to repair the bootloader of OS...
try BCEdit...HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
adding the internal Hard disk (1TB) to the existing PC
By SeenuGuddu in forum PC Components / ConfigurationsReplies: 7Last Post: 02-03-2012, 06:05 PM -
Hard disk Question(Which hard disk to install the OS)
By guru_urug in forum Hardware Q&AReplies: 4Last Post: 01-09-2011, 01:48 AM -
Internal Hard disk required
By brainwork in forum PC Components / ConfigurationsReplies: 11Last Post: 21-08-2011, 01:27 AM -
Suggest A Good Internal Hard Disk
By sreenidhi88 in forum Hardware Q&AReplies: 19Last Post: 04-06-2008, 07:24 PM -
80GB hard disk converted into 10780 MB hard disk
By ssingha in forum QnA (read only)Replies: 12Last Post: 24-08-2004, 11:57 AM
LinkBack URL
About LinkBacks
