Results 1 to 12 of 12
  1. #1
    Nov 2008
    Default How's is this config, Suggestion required
    Hi, friends i am getting this config tomorrow please suggest is this the best i can get under 35k+- cat..
    Dell Studio 14
    Processors : Intel® Core™ i5-460M 2.53GHz (2.8GHz Turbo Mode, 3M cache)
    Operating System : Windows 7 Home premium 64 Bit Chipset : Intel 965PM/GM Express Chipset
    Memory : 6 GB 1333MHz DDR3 SDRAM
    Hard Drives : 500GB configured with a 7200 RPM SATA hard drive
    LCD Display : 14-inch High Definition 720p WLED (1366×768) Display with TrueLife™
    Internal 10/100/1000 Gigabit Ethernet LAN
    Graphics : Intel GMA 4500MHD / 512MB ATI Mobility Radeon HD 4530
    Optical Drives : Internal 8X DVD+/-RW Combination Drive with dual layer write capabilities
    Integrated Speakers,Webcam,8-in-one card reader,Fingerprint reader
    Bluetooth(2.0 + Enhanced Data Rate),Intel(R) WiFi Link 5300 (802.11a/g/n) Half Mini-card
    Power : 9-cell 85WHr Li-Ion Battery
    Link to the website is : Dell Studio 14 (1458) and Studio 14z Laptop Details | Dell
  2. #2
    Manc xtremevicky's Avatar
    Dec 2009
    Bhopal / Bangalore
    Default Re: How's is this config, Suggestion required
    Looks good IMO.
    What is your primary use ?
    If you like the Post , There is a Rep Button ,
    If not then Understand that, There are people with different Opinions !
  3. #3
    Nov 2008
    Quote Originally Posted by xtremevicky709 View Post
    Looks good IMO.
    Thanks, for replying .. i want a balanced laptop with some good features. Mobility, power and vfm.. i am into network security so have to work on vmware alot..
  4. #4
    Alpha Geek marvelousprashant's Avatar
    May 2011
    Allhababd
    Are you getting this one for 35k. The link you provided redirects to dell US page. Good config if you get it for 35k
  5. #5
    Nov 2008
    yes... i am getting this in 35500lk ( will have to bargain a little also )
  6. #6
    May 2011
    Allhababd
    Quote Originally Posted by amd3000 View Post
    I don't think so. Studio models are not listed on dell india website. Inspiron 14R with i5 and 1gb graphics is available for 42k there
  7. #7
    Nov 2008
    yes.. actually i am getting this config through one friend.. ( actually my friends friend )... as its not directly from dell online .. asking if this config and model is good.. also i can't find much about this particular model in web also.. looks like almost all r copied from one link or another.
  8. #8
    May 2011
    Allhababd
    Go for it. You wont get a better configuration at this price.
  9. #9
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Hoping its not 45k.
    If you are getting this one for 35k then surely grab this. Its a steal deal.
    Check here
    My Blog :D
  10. #10
    Dec 2009
    Bhopal / Bangalore
    Well since you are into network security then this is the config for you. 6 GB ram does justice to that and as other said if you are getting this for 35K . Buy it now !
  11. #11
    Nov 2008
    Thanx guys... my finger is crossed.. as even i cant believe its more like too good to be true.. lets c .. just one more question how much performance up will i get if i go for i5 sandy bridge ( which is not availble in studio and have to opt for inspiron )..?
  12. #12
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    At most 5% difference. Go for the proccy yot mentioned. Its a well balanced config at a very good price.
  1. Suggestion Required
    By Adheip in forum Buying Advice
    Last Post: 20-06-2011, 03:18 PM
  2. Finally upgrading 9 year old PC!! suggestion required for very custom config
    By khmadhu in forum PC Components / Configurations
    Last Post: 22-03-2011, 11:40 AM
  3. Suggestion Required!!!!!
    By Gotenstar in forum Hardware Q&A
    Last Post: 17-04-2009, 07:52 AM
  4. Suggestion required
    By chetanbs77 in forum Buying Advice
    Last Post: 11-03-2009, 08:47 PM
  5. Required suggestion on GPU's
    By raghumachanie in forum Gamerz
    Last Post: 27-05-2008, 11:43 PM
