Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 13-04-2009, 12:46 PM   #1 (permalink)
Default Why laptop best...?
Laptop Computer :
A laptop computer (also called notebook computer) is a computer that integrates all the elements that needs to run properly, including a battery power supply, a screen and a keyboard, in a small casing....
Why a Laptop better than PC ?
The main advantage of a laptop computer versus a desktop computer is its mobility as well as its reduced size. On the other hand, the price is generally higher for slightly less impressive performance and the laptop's hardware configuration is much less adaptable, even though it is possible to connect additional external peripherals thanks to its numerous I/O ports.
Therefore, the motivation for buying a laptop computer must above all be a need for mobility or a need to save space.
Moreover, with the emergence of wireless networks, and WiFi in particular, it is becoming very easy to connect to the Internet in public Hot-Spots or simply in any room of your home as long as it is equipped with a WiFi terminal. For advanced multimedia uses (e.g. digital video manipulation, connecting a digital camera or an mp3 player, etc.), the choice should fall on both the computer's performance (both graphic as well as computing power) and on the types and number of I/O ports that are available....
laptop0123 is offline
Old 13-04-2009, 03:14 PM   #2 (permalink)
New Gen Guru
sujoyp's Avatar
Default Re: Why laptop best...?
I dont think laptop have any advantage other then mobility...I am a 5 year laptop user
I found laptop is...
1. Very delicate
2.poor sound quality compared to desktop
3. Need more maintainence
4.cant upgrade other then RAm and hard disk
5. Costly component
6.Small screen
7.Poor graphics
Soo my verdict Rs.30000 PC = Rs.50000 laptop (performance wise)
Photography Gears -
Nikon D3100 DSLR , Nikkor AFS VR 18-55mm , Nikkor AFS VR 55-200mm , Nikkor AF 50mm 1.8 , Nikkor AIS 55mm 2.8 Micro , Tamrac Velocity 6x Bag
Yougnou YN-465 flash , Vanguard ESPOD 203AP
Check my Best pics at -> http://500px.com/sujoyp
sujoyp is online now
Old 22-04-2009, 07:41 AM   #3 (permalink)
6x6
half way there
6x6's Avatar
8. narrow viewing angle
9. congested keyboard,
6x6 is offline
Old 27-04-2009, 08:59 AM   #4 (permalink)
10. Very poor gaming
Nokia N79
SE K310i
Xbox 360 Elite
P4 2.67 GhZ, 512 MB RAM, 1 TB HDD, Geforce 5200 (VRAM 128 MB), LG 23" Full HD Monitor.
karamvirk is offline
Old 27-04-2009, 09:23 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
11.very heavy repair costs once it is out of warranty
desiibond is offline
Old 27-04-2009, 09:41 AM   #6 (permalink)
The G-Axe Effect
gxsaurav's Avatar
Small screen size & resolution for Design related tasks
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 27-04-2009, 02:23 PM   #7 (permalink)
The Researcher
laptop is meant to be portable. Always desktop is better if portability is not an issue.
Ramakrishnan is offline
Old 27-04-2009, 02:35 PM   #8 (permalink)
Laptop is convenient to take along, and you can work outside with it.
Tomttdd is offline
Old 27-04-2009, 09:17 PM   #9 (permalink)
Hosting Specialist
If it is only portability, try the netbooks.
ExpertWebHost.NET- Reliable web hosting service
niceboy is offline
Old 27-04-2009, 09:24 PM   #10 (permalink)
damnbadman666
damngoodman999's Avatar
LAPTOP/NOTEBOOK is really useful for those who rather change their place frequently or dorm/hostel students
But never compare a laptop to Desktop --> a 40K custom desktop computer can beat the 75K laptop hands down !!
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 30-04-2009, 05:33 PM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
slightly less impressive performance??
Performance wise, they are miles apart. a 40k desktop can blow away a 40k laptop in every area.
PS: mobility isn't everything.
Old 30-04-2009, 06:45 PM   #12 (permalink)
Here Since 2003
Indyan's Avatar
Thread closed since this is not news.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
