Results 1 to 3 of 3
Thread: Laptop coolers
  1. #1
    jck
    jck is offline
    Nov 2008
    Default Laptop coolers
    how much better is a coolermaster cooler than a normal laptop cooler?
  2. #2
    Apprentice Fighter's Avatar
    Jul 2006
    Bangalore
    Default Re: Laptop coolers
    Firstly Coolermaster is a costly brand but definitely worth your bucks you spend on it.
    You will get a Laptop chill pad with 3 fans for 700/- whereas Cooler Master Coolpad would cost you around 3000/-
    Core 2 Duo T9600(2.8GHz, 6MB L2 Cache), Vista Ultimate, 15.4" (1440x900) LED Display, 8 GB (800MHz) Dual Channel DDR3 Memory, 7200 RPM Hard Drive 250GB, DVD+/-RW, NVIDIA Quadro NVS 160M1 256MB DDR2
  3. #3
    Aug 2008
    Please check out my review at http://www.reviewsworld.in/hardwares...tepal-infinite
    Please post your comments to the post and it will be seen by CM executives.
    Regards,
    Anand N
  1. Laptop Coolers under 3k.
    By saswat23 in forum Laptops and Netbooks
    Last Post: 13-07-2011, 07:26 PM
  2. CPU Coolers
    By papa in forum PC Components / Configurations
    Last Post: 02-12-2010, 09:00 PM
  3. want to know more about cpu coolers
    By guru280789 in forum Hardware Q&A
    Last Post: 04-06-2010, 07:37 PM
  4. VGA Coolers
    By khandu in forum Hardware Q&A
    Last Post: 25-10-2006, 01:03 PM
  5. 3rd party coolers for CPU and GPU
    By abhijit_reddevil in forum Graphic cards
    Last Post: 30-04-2006, 02:49 PM
