Go Back   Digit Technology Discussion Forum > Portables, Peripherals and Electronics > Laptops and Netbooks
Laptops and Netbooks Buying advice for laptops, netbooks and tablet PCs to be posted here.
Old 18-12-2008, 11:00 PM   #1 (permalink)
Exclamation High-End Laptop, Urgent HElp Reqd!
Hi guys,
Just joined in today and scanned all the topics regarding a gaming laptop. I am planning to buy a good gaming laptop under about 85k, but the thing is that i dont want to regret buying it after a few months knowing dat sum oder newer models wid high specs are launched just after me buying d lappy.
What all i came upon was..
1.)Acer 8920g--great config, but couldnt find it ANYWHERE in bangalore..is it gone??
2.) HP dv5-1016TX- really impressed by it, but some members were saying dat HP are gonna replace dis model soon...shud i wait??
3.) Dell Studio 17 with customisation-- is the amd GC available wid it gud enug for med-high gaming?
3.)any other brand dat can come in my range.
Guys, really desperate here....plz help coz have to buy d laptop before going back to college...plus HP has an offer of philips 5.1 system upto 31st dec...
All comments welcome.
Vibhu12 is offline
Old 26-12-2008, 09:17 PM   #2 (permalink)
Default Re: High-End Laptop, Urgent HElp Reqd!
guys...u disappointed me...no replys??? all gone home??
well i think im gonna buy d 1016 if i get it.....
Vibhu12 is offline
Old 26-12-2008, 09:35 PM   #3 (permalink)
v4u_luv2004's Avatar
Some of the best available Gaming Laptops..
The first is the Alienware Area-51 m15x. It has a 2.8GHz Core 2 Extreme X9000 processor. The laptop has a 4GB DDR2 RAM and a 200GB hard drive. It has a TFT screen measured at 15.4-inch and a Blu-ray burner/DVD±RW drive. Also provided is a 320GB removable hard drive.
Then is the Maingear eX-L laptop computer with a 3GHz Intel Core 2 Extreme X9100 process and a 4GB RAM. It is equipped with 2 320GB hard drives and a Double-layer DVD±RW drive. The laptop has a display of 17-inches and a Dual ATI Radeon HD 3870. It runs on the Windows Vista Ultimate Operating System.
There also is the Gateway P-7811FX which runs on a 2.26GHz Intel Core 2 Duo P8400 processor supported by a 4GB RAM. For the hard drive it has one with 200GB of data space. Also included is a DVD±RW drive. It also has a 17-inch display and runs on the Windows Vista Home Premium (64-bit) Operating system.
Then there is the iBuypower Battalion 101 CZ-9 Ultra with an Intel Core 2 Duo T9400 processor running at 2.5 GHz. It also has a 250GB storage capacity with a 4GB RAM and a DVD±RW drive. The display is 15.4-inches and it runs on the Windows Vista Home Premium operating system.
The last but not the least is the Eurocom M570TU Montebello running on the 2.53GHz Intel Core 2 Duo Processor with 4GB of RAM and about 320GB of storage capacity. Equipped with a wonderfully clear 17.1-inch display and efficient DVD±RW drive. This wonderful laptop runs on the 64-Bit Windows Vista Ultimate Operating system.
And have a look here too Apple Have Something for you
http://www.apple.co.in/store/flash/macbook/macbook.html
v4u_luv2004 is offline
Old 27-12-2008, 12:56 AM   #4 (permalink)
jck
msi series have great gpu's
jck is offline
Old 27-12-2008, 09:05 AM   #5 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
I think he went home..
Btw alienware laptop you suggested I think it will be well over 1lakh.
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 30-12-2008, 02:58 PM   #6 (permalink)
thanks v4u_luv2004....but i dont think i could've had found those laptops in india with ease....so i went for dv5-1016tx....bought it yesterday....feels good till now...havent tested its gaming capabilities...
But what i noticed is dat the 1016tx gets heated up reasonable fast upon some media playing n file transferring...is dat normal for it...shud i go for a heat sink or something??
Vibhu12 is offline
High-End Laptop. Urgent. pickster Laptops and Netbooks 6 18-12-2008 05:16 PM
WHICH MOBILE TO BUY... URGENT FEEDS REQD. jay4u Buying Advice 19 16-04-2006 03:31 PM
Urgent Sugestions reqd. speedyguy QnA (read only) 11 21-02-2005 01:46 PM
URGENT HELP REQD........ liquid_nitrogen88 QnA (read only) 6 20-12-2004 09:55 PM
