Results 1 to 6 of 6
Thread: Internet Help?
16-08-2008, 02:19 AM #1
Internet Help?
I want to know how people connect their wireless internet? I heard about Data Cards....What is this Data Cards?How to configure it and how can i identify in the laptop where to insert it? Iam not an expert about laptops
....So Please help ?
SR
16-08-2008, 02:01 PM #2Broken In
- Join Date
- Aug 2008
- Location
- Mumbai, India
- Posts
- 160
Re: Internet Help?
It would help if you told us about your laptop (make and model). Might be that it has Wi-Fi already in it and you don't need the card.
16-08-2008, 08:06 PM #3
Re: Internet Help?
Its Lenovo 3000 G400........and plzz help me I dont about data cards?
SR
16-08-2008, 08:26 PM #4Broken In
- Join Date
- Aug 2008
- Location
- Mumbai, India
- Posts
- 160
Re: Internet Help?
I can't find that model on lenovo india website anymore. The nearest is G410. But, the site does state that all G Series are equipped with Wireless solutions. View this page: http://www-604.ibm.com/webapp/wcs/st...86018425154304 and scroll down to the G Series features section.
Consult the user manual about wireless and how to switch it on. Most probably, there is some push button on the laptop something like this:
to switch on wireless.
16-08-2008, 08:35 PM #5
Re: Internet Help?
@Original Poster
Data cards use the CDMA network for all data uploads/downloads.
Data card maybe of three types;
1. USB Plug-in : Goes into the USB port.
2. PCMCIA Card : Goes into the PCMCIA Slot on your Lappy. View the manual to know if you have one and where it is located.
3. Expresscard type : Like PCMCIA card but different slot.
The easiest and most versatile will be USB one, as you can use it in any laptop, desktop, as all have USB in them.
@Bandu
What you are talking about is Wireless LAN, The poster mentions about Data cards and wireless Internet. Lan and Internet are actually very different things.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
16-08-2008, 08:39 PM #6Broken In
- Join Date
- Aug 2008
- Location
- Mumbai, India
- Posts
- 160
Re: Internet Help?
Geeeeeeeeeeez... Ignore all my posts above. I should've read his questions properly.
*Logs Off*
How to connect my android to the internet using my laptop's internet dongle
By izzikio_rage in forum Mobiles and TabletsReplies: 15Last Post: 25-06-2012, 03:53 PM -
By izzikio_rage in forum Buying AdviceReplies: 1Last Post: 18-06-2012, 09:38 AM -
Using internet on Galaxy Tab using internet-enabled WiFi Laptop
By mvishnu in forum NetworkingReplies: 5Last Post: 22-02-2012, 01:02 AM -
Cheapest Internet Device - Free Internet via TATA CDMA phones ??
By Choto Cheeta in forum Mobiles and TabletsReplies: 23Last Post: 31-07-2008, 02:58 PM -
Internet via mobile.. Too slow internet and mozilla prob
By phuchungbhutia in forum Open SourceReplies: 11Last Post: 27-07-2008, 07:59 AM
LinkBack URL
About LinkBacks
