Results 1 to 3 of 3
Thread: Dialup Internet Problem
19-07-2008, 08:33 PM #1Obsessed with Technology
- Join Date
- Dec 2007
- Location
- Harihar
- Posts
- 355
I have 56k internal d-link modem.
I connected using netone as username and password to 172222. It gets connected but i cant do anything. No page loads or anying on every browser i tried. it connected at 31.2 kbps speed
Please help as modem working fine as i can call from it and also internet gets connected but i cant open any website or do anything with internet
Is it common with dialup or any probs thereAMD Athlon 64 X2 Dual Core Processor 4200+ 2.19 GHz, 2.5 GB Ram, 1 TB Hard Disk, MSI 6670 GFX
Visit my blog at devrathnd.blogspot.com
19-07-2008, 11:52 PM #2
Re: Dialup Internet Problem
ages since i v used dial up
try connecting yahoo messenger or gtalk n see if it connects
else
goto start >> all programs >> accessories >> command prompt and type "ping www.google.com" without quotes and n see if you get a reply
else
try going to the same command prompt type "ping 209.85.153.104" and see if you get a reply.mekalodu
19-07-2008, 11:55 PM #3Wise Old Owl
- Join Date
- Jul 2004
- Posts
- 1,351
Have you used this connection and account before or is this the first time ?
It sometimes happens that you can connect to your local BSNL server, but their connection to the internet gateway is down. Try again at another time and see if it works.
SE GPRS dialup Problem
By Gigacore in forum QnA (read only)Replies: 4Last Post: 30-09-2007, 08:25 PM -
help me setup a smartlink dialup modem and connect via sancharnet dialup
By prashanthnbhat in forum Open SourceReplies: 4Last Post: 26-06-2006, 04:15 PM -
DIALUP NETWORK PROBLEM........
By kool in forum NetworkingReplies: 4Last Post: 12-03-2005, 05:51 AM -
which is the cheapest way of getting internet except dialup
By rajeshjsl in forum Internet & WWWReplies: 26Last Post: 15-02-2005, 08:57 AM -
Dialup Internet access on Linux!!
By ankitjain in forum Open SourceReplies: 7Last Post: 20-12-2004, 12:24 AM
LinkBack URL
About LinkBacks
