Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 17-02-2008, 11:43 AM   #1 (permalink)
Default Weird Internet Problem.
Some sites like gmail.com, MSN.com and Messengers (Yahoo,MSN, Gtalk) are not working anymore.
First I thought it is a virus which by AV couldnt beat so I formatted and reinstlalled all but still same thing
Has some one else faced similiar prob before with BSNL? If yes whats the solution
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 17-02-2008, 12:07 PM   #2 (permalink)
WebDev :)
Gursimran's Avatar
Default Re: Weird Internet Problem.
Are you working behind any firewall?
Gursimran is offline
Old 17-02-2008, 02:37 PM   #3 (permalink)
Its my Home PC. I got QuickHeal Installed. Opera / IE etc are all allowed. Other sites open fine but not above.
Also Firewall warns for access of Program when it tried to connect. So far it hasnt did that either.
MSN Messneger Troubleshooter says: Default Gateway has some problem and make sure you are connected to internet.
Tech_Wiz is offline
Old 17-02-2008, 08:27 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
1) try to open blocked sites in other browsers.
2) Disable all firewall and try to open blocked sites and messenger.
ravi_9793 is offline
Old 17-02-2008, 10:57 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
Try Troubleshooting : If You Are Unable To Open A Particular Website.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-02-2008, 11:17 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
Change your DNS to OpenDNS
208.67.220.220
208.67.222.222
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 18-02-2008, 09:08 AM   #7 (permalink)
How to do that Core?
That DNS Setts in Network Options?
Tech_Wiz is offline
Old 18-02-2008, 11:47 AM   #8 (permalink)
slugger's Avatar
then
slugger is offline
Old 18-02-2008, 12:51 PM   #9 (permalink)
Thanks slugger. That was most useful
Will check it out when I get home
Tech_Wiz is offline
Old 19-02-2008, 06:53 PM   #10 (permalink)
Intel OCer
amitash's Avatar
try to flush ur dns..command prompt type ipconfig /flushdns
it mite be helpfull if u post a hijackthis log...some sites were blocked on my comp...turns out it was a virus,i saw hijackthis and saw that these sires were being redirected to an error page...all i had 2 do was remove tis file...
amitash is offline
weird problem-plz help calvin Hardware Q&A 2 28-05-2007 10:33 AM
Weird Lan Problem zodiac_511 Networking 3 25-09-2005 08:27 PM
Weird Internet Explorer Icon vwad Software Q&A 2 20-04-2005 01:23 PM
Weird UPS problem.... Nehaonline QnA (read only) 16 07-02-2005 12:18 AM
