Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 22-03-2007, 02:01 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Orkut scrapbook help ! ! !
how 2 send a scrapnote 2 a person without visiting his\her profile page ?
is it possible ...
ax3 is offline
Old 22-03-2007, 02:18 PM   #2 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Re: Orkut scrapbook help ! ! !
nope this isn't possible...
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 22-03-2007, 02:29 PM   #3 (permalink)
ThE oNE & ONlY ??
mikeon's Avatar
I guess its possible if you download the google talk application...
R.I.P 2pac, Biggie & Proof
Holla atcha' wherever you are !!!
mikeon is offline
Old 22-03-2007, 02:34 PM   #4 (permalink)
Tech Geek's Avatar
Nope still it is not possible....
Tech Geek is offline
Old 22-03-2007, 02:40 PM   #5 (permalink)
google talk is only for chattin purposes n just gives u a msg whenver sum1 writes u a scrap.........
Old 22-03-2007, 02:44 PM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
try this:
Search for the uid of the person in the address bar. It will be a 20 digi number.
Now type it at the end of this in the address bar:
http://www.orkut.com/Scrapbook.aspx?uid=xxxxxxxxxxxxxxxxxxxx
Replace the x with the uid of your friend. This way you may bypass his profile and jump directly in to his scrapbook
Nokia N86 8MP
Lucky_star is offline
Old 22-03-2007, 03:00 PM   #7 (permalink)
Resident Fanatic
Manshahia's Avatar
if u hav his replies then u can just reply from there without visiting his profile . ....
Manshahia is offline
Old 22-03-2007, 03:20 PM   #8 (permalink)
Google Bot
Pathik's Avatar
yea manshahia is rite.. Or u can use scrapboy or orkut cute..
Pathik is offline
Old 22-03-2007, 04:13 PM   #9 (permalink)
ax3
ax3's Avatar
will try it out .......... thanx 4 replies ............
ax3 is offline
Old 22-03-2007, 05:10 PM   #10 (permalink)
You'r Born Free
int86's Avatar
Can I scrap in disabled profile visit and get reply from him.
In doing so Can ne know who sent the scrap.
One more thing when I log to two different account in two separate browser, I get the contents in adress bar same. whats the cause. Can anyone know the accounts are of same person.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 22-03-2007, 05:23 PM   #11 (permalink)
Google Bot
Pathik's Avatar
if u scrap any1 then he ll obviously know who scrapped him witout doubt..
if u disable profile visitors than u ll not appear in the list of ppl who had seen his profile no matter wat u do in his profile...
i didnt understand ur 2nd query..
Pathik is offline
Old 22-03-2007, 05:37 PM   #12 (permalink)
You'r Born Free
int86's Avatar
I have two diff orkut account. I log with them in two differnt browser. One FF nad other Opera.
When I am logged to both accounts at same time , the adress bar had the same content(i.e. same http://www.orkut.com/Scrapbook.aspx?...xxxxxxxxxxxxx).
Does any one can know that these account are of same person.
int86 is offline
Old 22-03-2007, 05:43 PM   #13 (permalink)
Resident Fanatic
Manshahia's Avatar
i think the scrapbook number in 20 digits is unique to a person.....
same as a user id which u can get when u log in as uid=XXXXXXXXX....
Old 22-03-2007, 06:11 PM   #14 (permalink)
Google Bot
Pathik's Avatar
yep.. the user id is different for each user...
so it cant be the same... maybe orkut detected another uer logged in and auto logged u in that same account..
Pathik is offline
Old 22-03-2007, 06:16 PM   #15 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
ORKUT SUCKS!
rakeshishere is offline
Old 22-03-2007, 06:19 PM   #16 (permalink)
You'r Born Free
int86's Avatar
no they were two diffrent account
int86 is offline
Old 22-03-2007, 07:15 PM   #17 (permalink)
Resident Fanatic
Manshahia's Avatar
u are unable to make ur point...
u r not asking the question the rite way....
Originally Posted by rakeshishere
ORKUT SUCKS!
DONT GO OFF TOPIC
- by kool
