Results 1 to 20 of 20
Thread: Simple Machines Forum
16-03-2007, 07:42 AM #1
I have installed Simple Machines Forum but how to set up a forum. i extracted the files. how to open a PHP file?
16-03-2007, 09:10 AM #2
Re: Simple Machines Forum
http://www.simplemachines.org/smf/readme_install.html
http://www.astahost.com/info.php/how...smf_t6176.html
If your hosting has Fantastico, you can easily install it from there in a few clicks
http://www.host4cheap.org/
16-03-2007, 09:30 AM #3
what's fantastico?
16-03-2007, 09:35 AM #418 Till I Die............
- Join Date
- Jul 2004
- Location
- India, Mumbai, Marine Lines
- Posts
- 5,792
Where are you trying to set it up? At a remote server or your PC?
http://www.bash.org/?258908
16-03-2007, 09:38 AM #5
fantastico is fantastico it allows u to automatically install phpbb, smf, blogs, and all on ur site .... u click once it will do the rest .... ur host provides u with fantastico
http://beingmanan.com
16-03-2007, 10:17 AM #6
16-03-2007, 10:41 AM #7
my PC. i have just downloaded the SMF and extracted it. now how to setup my own forum?
Originally Posted by tech_your_future
16-03-2007, 10:45 AM #8
Oh on your PC. You will need to setup WAMP server.
WAMP - Windows, Apache, MySQL, PHP
If you are unsure on how to do this. I suggest download Xaamp or EasyPHP. Both are very good WAMP Packages
16-03-2007, 10:58 AM #918 Till I Die............
- Join Date
- Jul 2004
- Location
- Posts
- 5,792
Download and install xampp, it's an easy to start server, which has apache, php and mysql
Homepage - http://www.apachefriends.org/en/xampp.htmlhttp://www.bash.org/?258908
16-03-2007, 11:58 AM #10
So I Would Have To Download A 25mb Program To Run A 64kb Program
16-03-2007, 12:01 PM #11
SMF is not 64 KB
See in order to Run PHP on your PC you need to have APACHE, MySQL, PHP on your PC.
If you dont want to download 25MB, Download EasyPHP from Easyphp.org. It is 8-9 MB i think.
16-03-2007, 12:07 PM #1218 Till I Die............
- Join Date
- Jul 2004
- Location
- Posts
- 5,792
How are you gonna run SMF? I mean which web server will you be using then?
16-03-2007, 12:11 PM #13
i don't know anything abt this. all i know is i want to setup up a forum with any software.
16-03-2007, 12:15 PM #1418 Till I Die............
- Join Date
- Jul 2004
- Location
- Posts
- 5,792
You will require some web server, mysql and php to set up the forum. XAMPP is the easiest for beginners IMO.
16-03-2007, 01:17 PM #15
EasyPHP and Xaamp IMHO
16-03-2007, 01:17 PM #16
@pritish_kul2
register at any of the free web hosting sites which has forum also. Or else if u wanna ur own domain name, then buy some paid website [will be around 500~1000/- per year]. If u wanna setup server in ur home then your internet connection shud be incredibly fast[more than 2MBPS unlimited] for at least for some 20~30 people to login simultaneously into ur forum.G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518.
G3: XPS M1530 |
FZ 16.
16-03-2007, 01:20 PM #17
I think, he just setting up forum at his own pc to learn and not for practical purposes
16-03-2007, 01:54 PM #18
use any free host like 6te.net 9999mb.com even 4 learning
16-03-2007, 02:21 PM #19
thanks everybody. but i would be more graeful if u provide me with a step - by - step procedure to create a forum
16-03-2007, 02:37 PM #20
its very simple ... dwnld easyphp ... install it and then it in its install directory u will fnd www named folder copy the smf/phpbb folder in it then if im not wrong .... go to 127.0.0.1/smf it will take u the install page .... and b4 tht create a user in mysql by going to the mysql panel .... accessing mysql and all u will find a good help document with images
Need a CHEAP CPU for: Websurfing+Virtual Machines
By outspoken in forum PC Components / ConfigurationsReplies: 27Last Post: 17-04-2011, 07:41 PM -
Plz suggest: connecting multiple machines
By RoCkSoLiD in forum Software Q&AReplies: 2Last Post: 09-07-2008, 12:12 PM -
shared fax machines
By shobhit_newgen in forum QnA (read only)Replies: 1Last Post: 26-05-2008, 12:52 PM -
A Simple Machines Forum Query
By navjotjsingh in forum Internet & WWWReplies: 1Last Post: 24-10-2005, 01:21 AM -
Virtual Machines
By starscream in forum QnA (read only)Replies: 5Last Post: 08-07-2005, 10:32 PM
LinkBack URL
About LinkBacks
