alright fart
i apologise
it is our duty as senior members to tolerate and be patient with n00bs like u
how old are u anywyas ?
doesnt matter
let me explain in a language that even u'll understand
i hope u understand "picture association" actually
lets give it a try shall we ?
this is an apple
its starts with a letter
A and ends with the letter
E
now repeat after me ...
A-P-P-L-E = APPLE
now that we have that out of the way
Firstly what buried topic are ya talking bout and whats this Yap bout “virtual pc is nothing but virtual Pc just that . You don’t even Know what the hell am talking bout or what the hell it is . I was talking bout Talking bout Microsoft’s Virtual PC software.
hmmm the topic is discussed .. and the problem solved .. that means its a dead and burried topic
but its ok .. ur a n00b it'll take u time to know the meanings and to grab hold of forum etiquettes
fortunately u just made it very easy for me to report u .. and i dun think ull last here long enuff to learn it on this forum atleast
besided ive been using virtual pc when u probably were still in ur diapers
look at the followin screenshots
lets take it step by step shall we ?
dun worry ill take it slow so ur brain can cope with me
Virtual PC is a powerful software virtualization solution that allows you to run multiple PC-based operating systems simultaneously on one workstation, providing a safety net to maintain compatibility with legacy applications while you migrate to a new operating system. It also saves reconfiguration time, so your support, development, and training staff can work more efficiently. Microsoft released Microsoft Virtual PC 2004 on December 2, 2003.
[/quote]
read the bold text in red very carefully
O BTW .. thats what YOU HAVE QUOTED URSELF
now read what u wrote below ...
hoho "Little knowledge is dangerous thing " COMPATIBILITY again proves you just read few help files where the hell does compatibility issue arise here; guess you just had to use the word "compatibility" couldnt resist the temptation to get it out of your system.
completely contradicting urself
besides i dun think u even know what u just said cuz i couldnt figure anything out
i dun think u even understand the concept of a virtual pc
i dread to think what u use it for
it is NOT MEANT to be used as a functional OS
Whoever told you its anything even near an OS
i didnt say it was an OS ... i said its OS emulation capabilities is not supposed to be used as a functional os
as u can see from the screenshots
first of all the cpu utilisation is killer
besides for any virtual PC u need to set aside some ram .. and assign a virtual hard disk
these very functions mention the virtual pc is meant to be used temporarily
like i said for old softwares which have compatibility issues
or some ppl use to test virrii on it
and even to check custom made boot disk
these are just some of the uses of virtual PC
tho using it as an OS is not one of them
since i repeat the above line quite often .. lemme break it down for u
suppose u use win xp .. and u use virtual pc for win 98
that doesnt make it a dual boot system
neither does it mean u can work in the virtual pc win 98 environment like u do on ur local environment
as in dont try to be adventurous and use it to surf the net, install programs etc etc. as REGULAR USE
And stone age boy what kind of system are you using which gets stressed up if you run few programs init.
the screenshots should explain everything
besides i dun have to justify my rig to u .. i can safely say its better than anything u could possibly dream off
the point as the screenshots clarify is .. that to run that virtual environment ur putting ur pc throught continuous stress cycles
imagine using it as a replacement for the OS
O BTW >.. this was a dual booting question
and ur reply was completely off topic
neither was it called for
but then again all ur posts are the same as ive seen
Sheesh kabab thats what your IQ level is so dont try to jump higher
Speeedy Guy has given a very Practical advice ; reinstalling is the easiest step to do rather than " right steps" (which shows your lack in practical knowledge).
Stop trying to comment at other people stuff go get a degree or something
just because some illeterate bugger posts some garbage and get 2000+ posting rank in a website Forum doesnt make him a some techno whiz...
Respect begets Respect ; so next time dont try to be smart;
No limits But Know your limits
Peace V
why are u talkin abt food ? i dun think u can think of anythign behind ur stomach
sppedy guy has NOT given a practical advice
if u followed my link u would know how to solve the situation
wasnt someone talkin abt little knowledge being dangerous somewhere here ?
as far as my practical knowledge goes .. ive been there done that.. i know what works and what doesnt
and my solution WORKS
i cant help it if u couldnt stop drinkin milk long enuff to try it out
as for my education ... i dun need to prove anythign there either ...
my degrees are for me ... my knowledge i put to use
it isnt to shut mouths like urs. ... so u can go ahead and say what u like
as for my posts ... hehehe ... forget it ... i think u'll know that if u look at them
i dun think u should be talkin abt respect
cuz u definitely dont deserve it
u see this forum doesnt work on "join .. come in..look for a topic ... and post YOUR opinion instead of the right solution .. and get ahead "
this doesnt get u respect ..
neither does it prove ur worth !
learn to keep it
