Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 13-11-2006, 11:04 PM   #1 (permalink)
Techno Freak
Default help opera for 6670
guys i have nokia 6670. with that i have hutch gprs.
In that i install the opera software ,letest version which i download yesterday only.
when i start opera then it start gprs but it shows only" contracting server"
after 5 min it says no reply frm yahoo server (if i want to open yahoo.com)
but when i open my defautl browser of nokia then every thing is smmooth but i don`t like that web broser.
i like opera.
if possible plz tell the alternative to opera for nokia 6670.
suyash_123 is offline
Old 13-11-2006, 11:38 PM   #2 (permalink)
aryayush's Avatar
Default Re: help opera for 6670
There is a 'Test connection' link in the Opera mobile browser. Click on it and see whether it is successful or not.
aryayush is offline
Old 14-11-2006, 12:30 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Should be in Mobile Monsters section
Thread Reported...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-11-2006, 06:29 PM   #4 (permalink)
Techno Freak
ok but i think that it`s a question so i posted in qna thread
Old 14-11-2006, 07:22 PM   #5 (permalink)
!FREEWARES!
Akshay's Avatar
Hav u configured ur connection? Open Opera, go to settings n select ur access point/service u want to connect using. In ur case, select hutch (or whtevr name it is called)
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 14-11-2006, 11:15 PM   #6 (permalink)
De@d
outlaw's Avatar
did u select the right access point ?
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 15-11-2006, 10:11 AM   #7 (permalink)
krazyfrog
Posts: n/a
AFAIK, 6670 always came with Access NetFront browser pre-installed. Why don't you use that. It might be on the free 64mb card that you get. Also in case of opera, go to settings and check every setting. Maybe you haven't configured the browser properly. You can also try and download the free Opera mini browser from mini.opera.com. Its quiet good too.
Old 15-11-2006, 02:50 PM   #8 (permalink)
Techno Freak
dudes i made every thing u told properly ie access point in same as the default browser use.
n prob is that there was prob in my mobile 7 mth ago so i myself formated the mobile thus all pre install net front is deleted?
i also did method told by aryayush ie test connction in opera but no respon i think opera is not supported by hutch .
since my frd having 6600 have same problem
- by kool
