Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 23-12-2004, 09:52 PM   #1 (permalink)
Bewitched!
xenkatesh's Avatar
Default firefox and maxthon help.......??????
how to save the pages which is in tabs
PS: all pages...in the tabs at the same time... within some clicks
may be there might be some option in firefox or maxthon.. plzzz tell me
all the pages ust be saved in html format. not archive format(i.e, in firefox..)
thanx in advance...
regards
venkatesh
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 24-12-2004, 12:19 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Well .. You wanna save the content of the tabs open or the address of the tabs ...?
For the second you can use Groups > Save windows as group
For the first, you can use the Autosave option .. Configure it first ..
Options > Maxthon Options > Save
Autosave as Whole Webpage (.htm, .html)
And then Select Autosave from File menu .. Or Right click on Tab and select AutoSave ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 24-12-2004, 09:39 AM   #3 (permalink)
How do we toggle between multiple tabs in Firefox?
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 24-12-2004, 06:53 PM   #4 (permalink)
Bewitched!
xenkatesh's Avatar
use ctrl + tab to toggle between the tabs...
Old 24-12-2004, 07:01 PM   #5 (permalink)
Bewitched!
xenkatesh's Avatar
@ it_wazant_me
no.. no...
ur mistaken..
i will tell u clearly...
Dude iuse to save some web pages which have nice articles.. i.e, news mysteries, info, cheats, etc.. all these are in tabs... now if i want to save those pages i need to save each tabs individualy. coming to the questions.... i need to save all the pages(in tabs) at the same time with in few clicks... got that... there is a option in firefox.. but it says that archives format i dont need that i need in.html format....
Old 24-12-2004, 11:42 PM   #6 (permalink)
I'm facing a problem with firefox. I was looking for an appropriate thread to put it in, think this one is just fine. The problem is when I log in to my Yahoo mail account and try to compose a mail, the section where the text is to be typed doesn't appear, instead a grey colored box appears where nothing can be typed. It doesn't happen so with IE. Any clue guyes?
indrajit is offline
Old 10-02-2005, 12:25 PM   #7 (permalink)
Er....Methinks this is the right thread to post......
Is there any Plugin/Extension for Firefox that lets one open the previously
opened pages like in Maxthon??
Alternatively is there any option to "Save" the Opened Pages under any
Group So that i need not open them all again the next time i start Firefox?
ycr007 is offline
Old 10-02-2005, 07:09 PM   #8 (permalink)
swatkat's Avatar
yeah...there's an extension called Session Saver, which saves the exact state of the browser when u close and restores it, with same page, tab positions etc., get it here...
http://www.extensionsmirror.nl/index.php?showtopic=166
swatkat is offline
Old 10-02-2005, 08:48 PM   #9 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Sreevirus (emmahater) posted how to do the same here...
He expalins how to do the same with tabbed browser preference extension.
To toggle between the tabs , one just has to keep his mouse pointer over the tab and the tab opens.
drgrudge is offline
Old 11-02-2005, 10:37 AM   #10 (permalink)
Thanx Swatkat n DrGrudge I got the Extension Now.....
Shall hafta see its working later when I open FF.....
ycr007 is offline
Old 11-02-2005, 07:01 PM   #11 (permalink)
vignesh's Avatar
Download the easygestures extension
vignesh is offline
Old 11-02-2005, 07:21 PM   #12 (permalink)
 Macboy
goobimama's Avatar
For saving tabs and stuff, use session saver. Then in the tools> session saver> under the capture menu, click New. then you name your session and every time you want to open those pages, just go to tools...blah blah blah...
I'm like a bird... :)
goobimama is offline
Old 23-02-2005, 01:23 PM   #13 (permalink)
Is there any Plugin in Firefox that allows users to upload
a pic directly to Imageshack?
I searched Mozdev but to no avail.....Maxthon has an Imageshack Plugin that
I downloaded but the Downloaded file has no .exe just a html and a cofig.
file.Should I place it in the Maxthon Plugins Directory??
I'm not a regular here but that doesn't make me a lurker :mrgreen:
ycr007 is offline
Old 23-02-2005, 06:14 PM   #14 (permalink)
drgrudge's Avatar
Here it is:
http://celebnamer.celebworld.ws/fire...hack-0.4.2.xpi
Just request for ur extensions in this thread as it will be easy for the members to help out others and u can search for the same as well.
http://www.thinkdigit.com/forum/viewtopic.php?t=13091
Post ur queries here next time!
drgrudge is offline
Old 24-02-2005, 01:03 PM   #15 (permalink)
Here it is:
Thanks Drgrudge...I shall keep in Mind the other Thread.
ycr007 is offline
Old 28-03-2008, 01:03 PM   #16 (permalink)
doing R&D of webtools
Default Re: firefox and maxthon help.......??????
Session saver in IE
find the add on here.
amitshahc is offline
- by kool
