I cant download via bit torrent.But i hav a very fast connection.So tell me some sites to download Movies,games,anything .But these should not be using bit torrent!!
Downloading movies,full version games are illegal.If you have very fast connection then mention it's speed.
I download from a cafe.Connection is 100Mbps.
They dont allow to use torrents.
Dont about mentioned sites use Bit torrent??
I dont like Sites which gives links to public file uploading sites.They are slow
__________
Where to download Movies??
Games??
Reason: Automerged Doublepost
@thilina: 100MB is not the actual speed,mine is 256Kbps connection and connection tray shows 12Mbps.Go to that link and test the speed: www.speakeasy.net/speedtest/
What you are trying is illegal. There's not going to be any help from here.
And yes the connection isn't 100mbps, it's just the max. speed supported by the LAN card nothing else.
