Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 20-07-2006, 08:36 PM   #1 (permalink)
anarchist
Posts: n/a
Default digit forum and Opera - attchment problem
i was using Opera browser, while replying a thread i have to attach an image but could not find "Manage attachment" button. while using IE this button was visible. anybody facing same problem?
Old 20-07-2006, 09:16 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: digit forum and Opera - attchment problem
No problem here. I use Opera v9.01.
EDIT: I think you have collapsed the additional option option. just below the edit post frame you will see a bar called Additional options . at the end of the bar you will see a updown arrow , click to toggle the additional options.
Charan is offline
Old 20-07-2006, 09:27 PM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
Its form this Blog Opera Desktop Team . BTW i had edited my reply did you chk it ?
Charan is offline
Old 20-07-2006, 09:35 PM   #4 (permalink)
anarchist
Posts: n/a
are you talking about this? it is screen shot from opera
Old 20-07-2006, 09:37 PM   #5 (permalink)
Google Bot
Pathik's Avatar
it works kool on 9.00 Beta Build 8414.... and 9.01 is a lil bit unstable..
Pathik is offline
Old 20-07-2006, 09:46 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
seems unusual. I am using Opera 7.54 version but dont have problem like this.
http://twitter.com/blueshift155
blueshift is offline
Old 20-07-2006, 11:52 PM   #7 (permalink)
Rubik's Uncle!!
Charan's Avatar
WOW yea but i dont see that button , now i see the problem , wierd
Charan is offline
Old 21-07-2006, 09:38 AM   #8 (permalink)
anarchist
Posts: n/a
now i downloaded version 9.01 build 8533, it is also having same problem.
@charangk: i have downloaded from the link provided by you. does your browser works with attachments?
Old 21-07-2006, 10:05 AM   #9 (permalink)
Rubik's Uncle!!
Charan's Avatar
hooo what hapnd . After reading your post, i went to post a attachmant and......... now even im facing the same problem . this is really strange.
EDIT: if i try to edit this reply then i can see that button .
Charan is offline
Old 21-07-2006, 10:08 AM   #10 (permalink)
Rubik's Uncle!!
Charan's Avatar
ha ha ha really wierd. while posting the above i didnt see the "manage attachment" button , now i see it . really strange.I have attached a text file called text.txt .
File Type: txt test.txt (16 Bytes, 3 views)
Charan is offline
Old 21-07-2006, 11:04 AM   #11 (permalink)
18 Till I Die............
Well I can see those buttons. I am using Opera 9.01 for Linux build 376.
http://www.bash.org/?258908
mehulved is offline
- by kool
