Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 11-04-2006, 09:21 PM   #1 (permalink)
Default internet problems
i've got a mtnl broadband connection.for the past few daze its been givin me problems as in it suddenly stops workin..also sometimes when i leave the computer and come back after 15-20 mintues i find that its stopped workin.if i restart the comp or log off and login again the problem is solved..
cud nyone suggest a solution cuz i jus cant keep logging off and loggin in all the time.
thnks a lot for ur time
kreigsmarine is offline
Old 13-04-2006, 11:45 PM   #2 (permalink)
sknowonweb's Avatar
may be your connection property is set to disconnect when it reaches a idle time limit (like screen savers).Try looking for this property value
sknowonweb is offline
- by kool
