Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 11-12-2005, 03:31 PM   #1 (permalink)
Default Slow Speed Internet
My Internet speed is very very slow. I am using a Internal Modem. There is no Broadband facility available in our area. Is there any way?
kumarn_2004 is offline
Old 11-12-2005, 03:34 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
well, speed dial up cons depend more on ISP provider
and ofcourse the traffic
just try reducin the HTML content frm the web pages
tht will allow loadin the webpages faster
isn't dataone available at ur place
all it needs is a telephone !!!
vijay_7287 is offline
Old 11-12-2005, 03:46 PM   #3 (permalink)
readermaniax's Avatar
Ensure that you have the latest drivers for your modem, from the manufacturer & not Microsoft.
Here are some tweaks that will help you maximize throughput as best possible, for your 56K modem.
Please create a System Restore point before tweaking
Download Cablenut & use the following settings:
DefaultReceiveWindow = 8192
DefaultSendWindow = 4096
DisableAddressSharing = 1
InitialLargeBufferCount = 10
InitialMediumBufferCount = 24
InitialSmallBufferCount = 32
LargeBufferSize = 4096
MaxFastTransmit = 6400
MediumBufferSize = 1504
PriorityBoost = 0
SmallBufferSize = 128
TransmitWorker = 32
FastSendDatagramThreshold = 1024
EnableFastRouteLookup = 1
EnablePMTUDiscovery = 1
IgnorePushBitOnReceives = 0
GlobalMaxTcpWindowSize = 8760
MaxFreeTcbs = 2000
MaxHashTableSize = 4096
MaxNormLookupMemory = 5000000
SackOpts = 1
SynAttackProtect = 1
Tcp1323Opts = 0
TcpLogLevel = 1
MaxDupAcks = 2
TcpMaxHalfOpen = 100
TcpMaxHalfOpenRetried = 80
TcpRecvSegmentSize = 1460
TcpSendSegmentSize = 1460
TcpTimedWaitDelay = 30
TcpUseRFC1122UrgentPointer = 0
MaxConnectionsPer1_0Server = 8
MaxConnectionsPerServer = 4
DefaultTTL = 128
DisableUserTOSSetting = 0
TcpMaxDataRetransmissions = 6
DefaultTOSValue = 92
Open your registry (start -> run -> type regedit) and change the following registry entry:
Export each registry setting before amending
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\AFD\Parameters
Add the parameter BufferMultiplier and give it a value of 400 hexidecimal which will make it 1024.
Download TCPOptimizer and use the following settings:
Under the settings tab select dial up and custom settings, in network adapter selection choose dial up adapter. Then use the following settings:
MaxMTU - 1500
TCP Receive Window - 8760
MTU Discovery - Yes
Black Hole Detect - No
Selective ACKs - Yes
Max Dup ACKs - 2
Time to Live (TTL) - 128
TCP 1323 Options - uncheck both boxes
Other settings:
Max Connections per Server - 4
Max Connections per 1.0 Server - 8
Then select Apply changes and reboot your computer.
Go to Network Connections from the Control Panel – right click on your internet connection and select properties, uninstall QoS Packet Scheduler.
Amend the following registry entries:
delete the following entry
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Explorer/RemoteComputer/NameSpace/{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
add the following entry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\PriorityControl (if PriorityControl is not there, make the value) - on the right hand side right click and select new DWORD value, name it IrqXPriority (X = Irq assigned to your modem), then right click it and select modify and give
it a decimal value of 1.
This tweak will help web pages load faster, it has no real effect on download speeds, just helps your pc look up websites faster thereby speeding up
how fast the page loads and making websurfing more enjoyable.
Go to the registry entry and change the following settings:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\ServiceProvider
Class - 1
DnsPriority - 1
HostsPriority - 1
LocalPriority - 1
NetbtPriority - 1
Download CableNut in here
http://www.student.ipfw.edu/%7Egottj...ablenut408.exe
Download TCPOptimiser in here
http://www.speedguide.net/files/TCPOptimizer.exe
Credit goes to subs..the original author for writing this tweak. But i can't recall where i copy this tweak from...i'll post it in here if i found the site.
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 11-12-2005, 05:45 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
also try alternet browsers... & right now broadband connection cost is almost as low as dialup (leaving the Data cap beside)... so for normal surfing... do think that option...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-12-2005, 06:19 PM   #5 (permalink)
If you are using firefox browser , just install the extension faster fox. It may help you to load the pages little faster.
Win7 Ultimate 32/Intel CLASSIC DG43NB/Intel Core 2 Quad 8400 @ 2.66 GHz/4 GB RAM(2x2GB)/Nvidia Geforce 9400/Seagate 2TB & Seagate 500GB/LG16X/i-ball sprinter500/Samsung740N & SA300/APC ES650VA
Aanand is offline
Old 12-12-2005, 02:31 AM   #6 (permalink)
yrana2002's Avatar
You may even tweak the firefox settings for a slow connection to maximize your browsing speeds. Or you could try a webaccelerator such as onspeed .
For downloading, i suggest you use DAP. It has an option of Extreme accelerated speed, which may take your bandwidth to the maximum. It splits up file & searches for mirrors automatically.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
- by kool
