Go Back   Digit Technology Discussion Forum > Internet and Networking > Internet & WWW
Internet & WWW Web browsers, online services which you like, tutorials or questions about any online service on the web, this is the place
Old 04-10-2004, 11:56 PM   #1 (permalink)
Default Internet speed
Hi can anyone please help?
These days my net speed has become very poor I checked up the telephone line it is ok, but why it has become suddenly worse, my friends connection from the same ISP BSNL is ok?
gramesh is offline
Old 05-10-2004, 12:03 AM   #2 (permalink)
yes evev i have the same problem with BSNL of late the connect speed is 33.3 K as compared to earlier 46-47K so for the past few days i have shifted over to VSNL here the connect speed is back to 47K(same PC same tele line same user same ... everything). I wonder what BSNL is upto.
**** happens
pradeep_chauhan is offline
Old 05-10-2004, 12:11 AM   #3 (permalink)
#/bin/sh's Avatar
http://us.mcafee.com/root/speedometer/default.asp
check ur speed and tell what is actualy is?
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 05-10-2004, 12:16 AM   #4 (permalink)
28.5K The link you sent says NaN Kb this speed is from another test site.
**** happens
Old 05-10-2004, 12:21 AM   #5 (permalink)
hey i got 78.8Kbps (9.85KBps) is that gud or bad??? i am using a BSNL Direct Internet Access line in Kolkata...
...walking thru the twilight zone...there was no beginning...there is no...end...
www.baikunth.doornumber3.in
www.thefutureforest.com
FunkyB is offline
Old 05-10-2004, 12:22 AM   #6 (permalink)
when checked it was showing the following
Your Internet Connection
Speed Results
File Size: NaN KB
Time Elapsed: NaN seconds
(NaN KBps)
gramesh is offline
Old 05-10-2004, 12:30 AM   #7 (permalink)
sometime back I read it that if some commands are given in :extra initialisation commands: option it will work faster, but I do not remember what to give.
Also in one of the forums after seeing some juiceboosted etc broadband internet post I applied for that is that causing the problem, they told they will give the software on 1st october now I am not able to go to that site!!!!!!!
gramesh is offline
Old 05-10-2004, 12:33 AM   #8 (permalink)
guys use only IE for this test else NaN
**** happens
Old 05-10-2004, 01:38 PM   #9 (permalink)
Hi pradeep
Ichecked with MyIE2 it shows the following at 13:37 IST.
File Size: 150.005 KB
Time Elapsed: 30.274 seconds
39.6 Kbps
(4.95 KBps)
At night it worsens so badly I will check and let u know.
gramesh is offline
Old 05-10-2004, 07:59 PM   #10 (permalink)
NikhilVerma's Avatar
Time Elapsed: 36.281 seconds
33.04 Kbps
(4.13 KBps)
DUDE it's crap!!!
I easily get average download speeds of 6-7KBPS...
NikhilVerma is offline
Old 05-10-2004, 09:11 PM   #11 (permalink)
how come i have the worst figs ? wait let me catch the local lineman tomorrow and check up my local lead t the DP.
**** happens
- by kool
