Results 1 to 26 of 26
Thread: My PC is Infected Please Help...
04-07-2012, 10:34 AM #1
The first thing I do every morning is check my G-Mail. But today when I opened the page it showed me the error as shown in the attached image.
I;m using windows 7 64 bit edition and I've AVG free antivirus installed which fails to show up in the task bar.
Please help me out guys as soon as possible.
!!!!*Little Knowledge Is Dangerous*!!!!!
04-07-2012, 11:23 AM #2
Re: My PC is Infected Please Help...
Clear all cookies/cache of Chrome & recheck.
also install Avira Antivirus (better than AVG) & do a full system scan.HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
04-07-2012, 12:51 PM #3
It's expired because you are living in 2020. Check your time dude....
04-07-2012, 12:53 PM #4
^^^ +1 ...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
04-07-2012, 12:55 PM #5MrinTech | Exam Dunia :)
Some gadgets I own: Dell Inspiron 15R | Asus X53U-SX013D | iPad 2 | Samsung Galaxy S+ | PS3 :)
04-07-2012, 01:24 PM #6
04-07-2012, 02:10 PM #7
I know that, but the question is how did that happen. Till yesterday it was all good.It's expired because you are living in 2020. Check your time dude....
More over it was not showing my antivirus icon in the task bar as opposed to now.!!!!*Little Knowledge Is Dangerous*!!!!!
04-07-2012, 02:59 PM #8
04-07-2012, 03:46 PM #9
Check Your Time And Date.
I am Agree With @Gauravs90...!!ABOUT ME- http://about.me/ankitagrahari
Please Like My Facebook Page-- https://www.facebook.com/pages/Techn...44774892328288
And Visit My Blog-- http://technologyworm.blogspot.in/
04-07-2012, 04:41 PM #10In The Zone
- Join Date
- Apr 2012
- Location
- Kannur, Kerala
- Posts
- 202
Yaa check time.
If everything fails try kaspersky rescue disk and burn it on a cd(make it bootable). Try a full scan and delete the viruses.
Try and reply. Avg may not good(i think so).avira is better than avg for sure.
04-07-2012, 10:42 PM #11
05-07-2012, 11:27 AM #12
Thanks everyone...
I didn't do anything on my own. I assume it happened on its own. Even every time when I turn off and on my system the time and date is not correct. Though it happens to stay in the same year though
Anyway my AVG scan is working in safe mode and soon I will do complete scan and see what happens.
On the other thought is my PC is about 5 years old and my bios battery has never asked for a change. Could that be an issue ??!!!!*Little Knowledge Is Dangerous*!!!!!
05-07-2012, 11:33 AM #13
05-07-2012, 11:52 AM #14
05-07-2012, 07:21 PM #15
Hmm Did a complete scan in safe mode using my existing AVG antivirus. Not quite sure if all the areas were scanned but my system seems ok right now.
Will wait for few more days and see if the problem persists.!!!!*Little Knowledge Is Dangerous*!!!!!
09-07-2012, 10:17 PM #16
I'm still facing the issues with timing and all.
Did AVG scan in safe mode but it didn't help.
If anyone can name atleast One freeware that could come to rescue would be great.
I've used COMBOFIX in the past. But now when I've switched to 64bit architecture it doesn't seem to work anymore. If anyone has the link to 64bit version of COMBOFIX please forward me the link.
@SAM :- Tried using Emisoft, though it found out few faults and cleared them but the problem is still there..
Everytime I switch on my system. I've to change the time and then Log Off and Then Log In to load the startup files like antivirus and rest.
Guys help me out of this situation. This is the first time I'm facing an issue since I've started using WIN 7 .!!!!*Little Knowledge Is Dangerous*!!!!!
09-07-2012, 10:52 PM #17
as you said every time you restart time changes.. It means you need to change cmos battery.. just get a new one and then your date will be saved in memory when you turn your comp off..
anyway when you start your comp.. what date does it show.. I mean past date or future..(I love your comp which shows future..
Athlon II X4 635 @ 2.9Ghz Gigabyte GA-MA785GMT-US2H Kingston 2x2 Gb 1333Mhz DDR3 WDC 500Gb Green Palit GTS 250 512mb Tagan 500W Samsung B2030 Lg DVD Writer
09-07-2012, 11:24 PM #18
If the above suggestion of changing the CMOS battery works , then I am pretty sure his computer has been teleported from future.
09-07-2012, 11:26 PM #19
* Scan your PC with: Kaspersky Rescue Disk 10
* Change CMOS
Everything will be fine... else throw....
09-07-2012, 11:28 PM #20
Check the time in BIOS , and shut it down for a while. Now switch it on and check the time once again in BIOS .
If they are all the way same(~) , its gotta be your CMOS cell.
You can simply rule out the existence of any virus behind this if you get above results.
Btw , I was wondering that do we need to mention the AM/PM thing when using a 24H time clock.Last edited by Rishi.; 09-07-2012 at 11:34 PM.
10-07-2012, 09:46 AM #21
Initially when all this started it used to show the year 2020. These days it is showing 2014.Anyway I've thought of changing CMOS battery too.
But today as of now when I've started the system the date was accurate except the time which was off.
I'm downloading the Software now..Hope it is not too command based. Otherwise I'll be stuck
Ohkey will try this now..
I guess we do not mention AM/PM when in 24 Hrs format
13-07-2012, 07:37 PM #22Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 12
Check your Computer Date and Time. The problem should be fixed.
29-07-2012, 08:27 PM #23
Hey sorry for replying late. Actually I found a 64-bit version of combo fix. Ran it in safe mode and also changed the CMOS battery.
So no problem ever since.
30-07-2012, 12:43 PM #24
02-08-2012, 03:40 PM #25
Run a Malware Bytes scan, should help a LOT.
02-08-2012, 04:27 PM #26
virus . I thought so as cmos battery problem will show you past date most accurately time when your motherboard was manufactured not future as was in your case.
good to know problem solvedAthlon II X4 635 @ 2.9Ghz Gigabyte GA-MA785GMT-US2H Kingston 2x2 Gb 1333Mhz DDR3 WDC 500Gb Green Palit GTS 250 512mb Tagan 500W Samsung B2030 Lg DVD Writer
I've got infected
By Cool Buddy in forum Software Q&AReplies: 30Last Post: 12-11-2008, 09:41 PM -
Is my OS infected ?
By Dark Star in forum Open SourceReplies: 25Last Post: 17-02-2008, 09:33 PM -
Infected?
By Anindya in forum QnA (read only)Replies: 2Last Post: 13-12-2007, 06:51 PM -
Infected
By Ecko in forum QnA (read only)Replies: 1Last Post: 07-07-2007, 08:05 PM -
help me my pc is infected
By bholu in forum Software Q&AReplies: 11Last Post: 22-01-2006, 11:00 AM
LinkBack URL
About LinkBacks
I think OP Rested some thing on Bios time is the Default change it first
