my outlook used to work flawlessly till a couple of days ago when this dialog box started appearing ....
(this operation has been cancelled due to restrictions in effect on this computer)
the above error appears when i click on any hyperlink in my outlook mails .....
added: i am in admin login on my local system
EDIT:
i got the solution from
here
You receive an error message when you click a hyperlink in Outlook
View products that this article applies to.
Article ID : 310049
Last Review : June 9, 2005
Revision : 4.0
This article was previously published under Q310049
Important This article contains information about how to modify the registry. Make sure to back up the registry before you modify it. Make sure that you know how to restore the registry if a problem occurs. For more information about how to back up, restore, and modify the registry, click the following article number to view the article in the Microsoft Knowledge Base:
256986 (http://support.microsoft.com/kb/256986/) Description of the Microsoft Windows registry
On This Page
SYMPTOMS SYMPTOMS
CAUSE CAUSE
RESOLUTION RESOLUTION
Reset Web settings Reset Web settings
Export and import the registry key from another computer Export and import the registry key from another computer
Export the registry key from another computer Export the registry key from another computer
Import the registry key Import the registry key
APPLIES TO APPLIES TO
SYMPTOMS
When you click a hyperlink in Microsoft Outlook, you may receive the following error message:
This operation has been cancelled due to restrictions in effect on this computer. Please contact your system administrator.
Back to the top Back to the top
CAUSE
After you upgrade to Microsoft Internet Explorer 6.0, the following registry key is either missing or corrupt:
HKEY_Local_Machine\Software\Classes\htmlfile\shell \open\command
RESOLUTION
You may be able to resolve the issue by resetting Web settings in Internet Explorer. If that does not resolve the issue, import the registry key from another computer.
Reset Web settings
1. Start Internet Explorer.
2. On the Tools menu, click Internet Options.
3. Click the Programs tab, and then click the Reset Web Settings button.
4. Under Internet programs, verify that the correct e-mail program is selected.
5. Click to select the Internet Explorer should check to see whether it is the default browser check box.
6. Click Apply, and then click OK.
Note You may receive the following message when Internet Explorer starts:
Internet Explorer is not currently your default browser. Would you like to make it your default browser?
If you receive the message, click Yes.
Warning Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate the following registry key: HKEY_Local_Machine\Software\Classes\htmlfile\shell \open\command
4. Click the command folder.
5. On the File or Registry menu (depending on your operating system), click Export.
6. Note the location of where the file will be saved. The registry file can be saved directly to the hard drive or floppy disk.
7. Type a unique file name, and then click Save.
8. Quit the Registry Editor.
1. Copy the Exported registry key to the desktop on the problem computer.
2. Double-click the .reg file.
You receive the following message:
Are you sure you want to add the information in drive: location file was copied to\file name.reg to the registry?
3. Click Yes, and then click OK.
APPLIES TO
• Microsoft Office Outlook 2003
• Microsoft Outlook 2002 Standard Edition
• Microsoft Outlook 2000 Standard Edition
Keywords:
kbregistry kberrmsg kbnofix kbprb KB310049
can someone send me the registry file ???
iinfi1 AT gmail DOT com
EDIT: [enoonmai] Please use the Edit button to effect changes.
