Re: GMail label name problem !!
Originally Posted by hittheswitch
I'll try my best to explain the problem that i'm facing.What i want to do is to apply label on my mails.... say i apply label xyz to mail no 7 to 10. The problem is that the labels should behave like folders.I know they are quite different from folders.
What i want is that if i applied label xyz to mail 7-10 then the mail shouldn't be shown in the inbox rather i should be able to access mail 7-10 when i click on label xyz.
This is to make my inbox a bit clean with a few important mails only.The stuff that i uploaded using Gmail drive should be in the label gmail and should not be shown in the inbox.I hope you all got the problem
TIA
dirtydignity
After putting those mails into a label, press the Archive button.
Or, if u want to always do both of these things(labeling and archiving) for mails with some keyword or from a paricular sender, then u can opt for creating filters. Kust click on the "create filters" link on top of ur inbox and u qill be guided from there.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
