Old 15-10-2008, 09:48 AM   #1 (permalink)
UBERGEEK
PCWORM's Avatar
Smile Help me build a pc within 12k...
One of my friends is assembling a pc for casual use at home..his max budget is 12k..
plz suggest a gud config which can be used for running windows-xp...
he needs a DVD-Writer in his config....plz help.
PCWORM is offline
Old 15-10-2008, 10:03 AM   #2 (permalink)
Designer Here
techking_dinesh's Avatar
Default Re: Help me build a pc within 12k...
u need a monitor also ??
wat parts u already hav ??
techking_dinesh is offline
Old 15-10-2008, 10:16 AM   #3 (permalink)
UBERGEEK
PCWORM's Avatar
yes he also needs a monitor...he is not having any parts already
PCWORM is offline
Old 15-10-2008, 10:21 AM   #4 (permalink)
12k is a bit tight... You can go for Sempron LE 1200+ with Asus M2A-MX combination (3800/-) or Intel Cel 1.8 GHz with Gigabyte 945 based motherboard (4300/-)... You can go for Sony DVD Writer, 1 GB DDR2 RAM, 80 GB HDD, Basic Cabinet model, and local kb and mouse... These together will come to around 9k (assuming the AMD approach)... If you get monitor 15" from cheaper brands like Zebronics, it will cost another 3.2 k... Then, UPS will set you back by 2k... So, without UPS it will come slightly more than 12k... With UPS, it will come near 14k...
Arun
NOTE: The rates are taken from http://www.deltapage.com/ which has the price listings of a Chennai based shop... If you are from other towns, there will be some variations in the rates...
sakumar79 is offline
Old 15-10-2008, 10:26 AM   #5 (permalink)
UBERGEEK
PCWORM's Avatar
thnx for those inputs...well it is his choice. If he is not willing to go above 12k then ill tell him to get the UPS afterwards..
PCWORM is offline
Old 15-10-2008, 11:43 AM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
very tight buget....
VarDOS is offline
Old 15-10-2008, 04:14 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
E2140 @ 2.5k
945GC @ 2k
1GB Transcend generic @ 0.7k
SAMSUNG(not 2nd hand)15" CRT @ 3k
Logitech kbd/mouse combo @ 0.8k
Zebronics & 400W @ 1.4k
Logitech R-10 2.0 @ 0.4k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 15-10-2008, 04:58 PM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
Originally Posted by comp@ddict View Post
E2140 @ 2.5k
945GC @ 2k
Creative R-10 2.0 @ 0.4k
Instead of it buy Zebronics Krish with 400W - 1.1k
VarDOS is offline
Old 15-10-2008, 08:12 PM   #9 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
E2140 @ 2.5k
945GC @ 2k
and add 200 and get Palit 610i instead of 945GC. Its worth it. Save money by replacing kbd/mouse with logitech basic, @ 500. it has no multimedia keys though.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 15-10-2008, 09:29 PM   #10 (permalink)
@comp @ddict - You have forgotten to consider HDD and DVD -Writer!!!
Arun
Old 16-10-2008, 03:53 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I'm very sorry
Well::
E2140 @ 2.5k
Zotac 610i @ 2.2k
Logitech kbd/mouse basic combo @ 0.5k
Zebronics Krish with 400W @ 1.1k
Seagate/Hitachi 80GB @ 1.5k
LiteOn DVD Writer @ 1.2k
About me:
Old 16-10-2008, 03:58 PM   #12 (permalink)
The Smaller Bang
Get a dual core atom with 945GC. I think it costs 3.5K. save 1K
And remove R-10 and replace with philips SBC9630 earphones for Rs. 50. save 350.
remove multimedia kbd/mouse and replace with logitech basic combo for 500. save 300.
you save enough for 1k dvd writer.
remaining is 650 saved. add more and get 80 or 160gb hdd.
dear comp@ddict: r-10 is from logitech not creative
Old 17-10-2008, 10:14 AM   #13 (permalink)
UBERGEEK
PCWORM's Avatar
Smile Re: Help me build a pc within 12k...
Thnx for the info guys,,,,
i wud rep back after assembling the config....thnx again!
PCWORM is offline
Old 17-10-2008, 04:03 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get the procc mobo combi i said, u dun want to suffer wid performance, no matter what budget do ya..then?
And sorry about the creative-logitech error
About me:
Build me a PC for less than 25K !! raksrules Gamerz 5 02-07-2008 11:42 AM
Want a build pc under 12k bhushan05d251 Hardware Q&A 1 02-11-2007 12:48 PM
Help Me Build my PC! Jikx Hardware Q&A 21 06-09-2006 09:41 PM
Help me build a PC sagargv QnA (read only) 10 10-08-2006 07:18 PM
Please help me to build my new pc birbal Hardware Q&A 14 14-07-2006 09:09 AM
- by kool
