Old 14-10-2008, 07:45 PM   #1 (permalink)
Default Help in choosing LCD monitor + Tv tuner card..
Hello friends,
I need your help in choosing LCD monitor + Tv tuner card.... Main purpose for viewing tv... So 22" monitor would be better... I would like to buy a higher end tv tuner card so that quality of pic is good... My budget for Tv tuner card is 5k and For lcd monitor is 15k....
Thanks in advance.....
sakthirajesh is offline
Old 14-10-2008, 08:19 PM   #2 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
Default Re: Help in choosing LCD monitor + Tv tuner card..
MONITOR ------------>DELL 22INCH 15K
TV TUNER --------------->PINNACLE 3.5K
ultimategpu is offline
Old 14-10-2008, 08:36 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
I think viewsonic will be gr8 as it comes with built-in speakers...so u can view TV without TV Tuner Card...
VarDOS is offline
Old 14-10-2008, 08:53 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Model number please.
ravi_9793 is offline
Old 15-10-2008, 11:49 AM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
ViewSonic - 22" 2235WM - 4 - Rs 13400
VarDOS is offline
Old 15-10-2008, 01:37 PM   #6 (permalink)
if one can watch tv without a tv tuner card , and has inbuilt speakers, then why not sell the model as LCD TV at a higher price???
TECH_MANAGER is offline
Old 15-10-2008, 01:59 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
Do you know model number of 26" monitor with S-video support??
Old 15-10-2008, 02:13 PM   #8 (permalink)
Point Blanc
afaik there is no 26 inch monitor in affordable range.
secondly the inbuilt speakers in viewsonic are not good enough to use much or always.
Though the monitors are good and have DVI port which is a plus.
Dell is compartively better. and same spec monitor is the one in 14,478 site price ~15K when tax is counted.
acewin is offline
Old 15-10-2008, 05:12 PM   #9 (permalink)
15.0 GHz
VarDOS's Avatar
ok close u r eyes and go for DELL
VarDOS is offline
Old 15-10-2008, 05:42 PM   #10 (permalink)
in viewsonic only one 28" model supports s-video all other models doesn't support S-video
this is the model vx2835
http://ap.viewsonic.com/in/products/...ecs.php?id=312
also from dell ultra sharp 2408 WFP (24")
http://www1.ap.dell.com/content/prod...hs1&l=en&s=dhs
and Dell UltraSharp 2709W (27")
hope this helps ...
if u want cheaper there are few models of LG which supports S-video and AV(composite) input ...
chilling.....
imgame2 is offline
Old 15-10-2008, 07:21 PM   #11 (permalink)
Hello friends,
Can you specify which model of pinnacle is good???
TV Tuner Card and LCD Monitor just like a normal LCD TV lahratla TVs / Monitors 1 27-08-2007 07:26 PM
Help me for choosing a tuner card... Sreekuttan Hardware Q&A 1 12-05-2007 05:54 PM
I need an LCD Monitor with inbuild TV Tuner Card.......... satyamy Hardware Q&A 1 22-04-2007 05:16 PM
Need an LCD monitor and TV Tuner card suggestion Aparajith Hardware Q&A 3 23-11-2006 09:52 PM
Help in Choosing the right TV Tuner Card amit_w QnA (read only) 21 27-02-2005 04:45 PM
- by kool
