Old 13-10-2008, 12:08 PM   #1 (permalink)
Exclamation high CPU utilisation prob
hi...
Whenever I start a new program CPU utilization increases to above 90%.Also it gets continuously remain above 10 % with red lines at the bottom of the graph.
Help me what to do!!!!
mgupta is offline
Old 13-10-2008, 06:26 PM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: high CPU utilisation prob
you must have opened a program that is utilising cpu....and for the red lines you have turned on the option of showing the kernel times....in the task manager go to view tab and click "Show Kernel Times" you wont be shown those red lines graphs...
Sooraj_digit is offline
Old 13-10-2008, 09:00 PM   #3 (permalink)
-----ATi-----
nvidia's Avatar
Download SysInternals Process Explorer and see which program is utilizing the processor. If the application is unimportant then close it and uninstall. It could also be some virus. Scan your computer once.
http://twitter.com/akshayms
nvidia is offline
Old 14-10-2008, 12:32 AM   #4 (permalink)
i do have this software but it doesnt show any weird program running with high utilisation.Actually the problem starts when I open explorer or any new program.I have checked my system for viruses,spywares and malwares, but nothing turned up.
mgupta is offline
Old 15-10-2008, 10:47 PM   #5 (permalink)
Do anybody have the solution???
mgupta is offline
Old 15-10-2008, 11:09 PM   #6 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
its may or may not be the problem of power -------- but im not sure about it which processor are u using and the motherboard with specification ????
ultimategpu is offline
Old 18-10-2008, 12:58 PM   #7 (permalink)
I m using Pentium D with Intel D102 motherboard...
mgupta is offline
Old 20-10-2008, 02:33 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
There is some oder app wich is causing this.
Y don't u format if there's no prob, shud wipe out the leeches in one go.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 22-10-2008, 10:02 AM   #9 (permalink)
speedyguy's Avatar
backup n format....this option rules...
Enjoy~!
No Pain...No Gain
speedyguy is online now
high compression mak1012 QnA (read only) 22 24-08-2006 11:03 AM
Act Of War : High Treason thunderbird.117 Gamerz 2 16-04-2006 08:50 PM
fly by fly fly high vaibhavlovegames Gamerz 2 21-03-2006 10:19 PM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
High high high end pc himtuna QnA (read only) 1 15-07-2005 12:43 AM
- by kool
