Old 16-10-2008, 03:51 PM   #31 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Gaming System : High End - Queries
Originally Posted by ultimategpu View Post
can anyone tell me what will be the between these 2 setups
1)AMD phenom x49550+asus m3a78-em(mobo)+palit 4850+2GB ddr2 ????
2)Intel core2quad6600+MSI p45 chipset + palit 4850+2GB ddr2???
using only for gaming and multitasking 3d rendering---------- can anyone help?????
1) bad, very bad
2) goddie
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 16-10-2008, 06:37 PM   #32 (permalink)
Designer Here
techking_dinesh's Avatar
This is not the right time to upgrade according to me because
1. Sensex done prices going high
2. w8ing for result on nehalem
3. lots of new tech coming which might make ur latest rig very ordinary
It is better to w8 till december and best to buy in march
well it is my opinion everything is up 2 u
techking_dinesh is offline
Old 16-10-2008, 06:51 PM   #33 (permalink)
k i just heard that future coming games building on the multi cores processing ---- and E8500 is the best proc for gaming right now but ---- the future games???
such games will come in about a years time ..and they will be very few ..initially..like may be farcry2 will support multi cores ..but i don't think they will perform like chalk and cheese with core 2 duo and core 2 quad .....E8400/E8500 is the best investment for gaming CPU if u want to use it for next 1-5 to 2 years...
---- can u tell about the core2quads and phenom 9550/9750 --- but in some tests AMD beats INTEL ----but INTEL scores better
intel core2quads gives u pinnacle of performance ..and i m not talking about Q6600 here ..Q9xxx series is simply superb
and what do u mean AMD beats INTEL ..but intel scores better ?? mostly in a benchmark if score is better it beats the other thing that has lower score..
i m aiming on the budget gaming for good performance /// thus 9550 and 9750 are the TLB bug cleared processor and it does low heat and quiet ---- c2q6600 is also good ----- i am so confused so can u tell me ????
C2Q is so much better in performance and thats the reason its costlier than ...X4 9550 and 9750..
simply having four cores doesn't always give great performance ..there is so much into architecture that can give overall performance ..and thats the case with C2Q ..if u want we can discuss the architecture in detail ..
chilling.....
imgame2 is offline
Old 16-10-2008, 10:51 PM   #34 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
[quote=imgame2;967463]such games will come in about a years time ..and they will be very few ..initially..like may be farcry2 will support multi cores ..but i don't think they will perform like chalk and cheese with core 2 duo and core 2 quad .....E8400/E8500 is the best investment for gaming CPU if u want to use it for next 1-5 to 2 years...
ok i am not asking about Q9xxx series intel ----------> i know this proc is good and it is not comparable wit AMD phenom ----------> but can u tell me about the q6600 that is also 65nm architecture , AMD 9850 beats q6600 is it true ????
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
ultimategpu is offline
Old 16-10-2008, 11:40 PM   #35 (permalink)
with latest price cut from AMD both the Proccy costs the same ...and AMD 9850 does perform a little better but consumes a hell lot more power and gaming performance is still not great compared to Q6600 ...Q6600 is old and will soon be replaced by Q93xx models ..for more info check this out
http://www.legitreviews.com/article/682/14/
http://www.firingsquad.com/hardware/...iew/page14.asp
http://hothardware.com/Articles/AMD-...vision/?page=9
http://www.techspot.com/review/93-am...on/page11.html
http://www.sharkyextreme.com/hardwar...61_3737046__11
http://www.zdnet.com.au/reviews/hard...9287832,00.htm
chilling.....
imgame2 is offline
Old 17-10-2008, 12:07 AM   #36 (permalink)
AMD & ATI FANBOY
Originally Posted by comp@ddict View Post
1) bad, very bad
2) goddie
does the AMD perform the hybrid crossfire with asus mobo --------> so how u say it is very bad ---------> i am not neglecting the E8400 its performance is different but what u say about the hybrid cross fire technology????
Old 17-10-2008, 10:18 AM   #37 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
[Offtopic]@ThreadStarter , Does Dell Ultrasharp 2408WFP supports HDMI? afaik Dell E248WFP was availeble for 24-25k ....Ultrasharp 2408WFP is 40k i guess?[/offtopic]
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 17-10-2008, 10:57 AM   #38 (permalink)
AMD & ATI FANBOY
if the monitor has 1080i that means it supports hdmi and blu ray
Old 17-10-2008, 04:21 PM   #39 (permalink)
not really so.. cos 1080i is a high-defination video mode ..while HDMI is audio and video(both) connector interface for transferring uncompressed audio and video streams..between various devices could be usd for LCD TV ,monitor,camcoders etc ...
its very plausible that a monitor can support full HD ..meaning 1080i or 1080p ..but it doesn't have an HDMI port ..or vice versa ..
for example dell SP2208WFP 22" has a HDMI port ..but it doesn't support full HD
for more info look here
http://en.wikipedia.org/wiki/HDMI#Co...ility_with_DVI
http://en.wikipedia.org/wiki/1080i
chilling.....
imgame2 is offline
Old 17-10-2008, 08:59 PM   #40 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
[quote=ultimategpu;967596]
No not at all true, even the 9950B.E> OCed to 2.8GHz barely manages!
About me:
Want To Use Linux for gaming(High End)!!My Options ;) Harvik780 Open Source 29 18-10-2008 10:21 AM
Any one with a high end gaming rig please post your configs here newneo PC Components / Configurations 14 13-10-2008 10:14 PM
High-end and gaming Mobos for Intel Core 2 Duo sabret00the Technology News 2 24-09-2006 08:52 PM
Help making a high end gaming pc in pune...???? ritwickgupta Hardware Q&A 9 03-05-2006 10:52 AM
want to go for a high end gaming system also want to use 3d ASH18MARCH QnA (read only) 6 24-06-2005 08:22 AM
- by kool
