Old 12-10-2008, 12:36 AM   #1 (permalink)
Default Having problem in installing my new 512mb SDRAM
Hey frnds I am having a trouble in installing a new ram in my P3 .recently i have purchased a 512 MB ram for my system.i have installed it properly but when i start my pc it shows only 128 mb ram n i also dont feel any difference in the speed of my system.i have checked the same ram on other systems also in them also it shows 128 Mb. so guys tell me is there any settings i have to do in my BIOS or something to make my ram work properly...
parag1985 is offline
Old 12-10-2008, 07:09 AM   #2 (permalink)
The Black Waltz
Default Re: Having problem in installing my new 512mb SDRAM
There's no other solution, just go back to where you got the RAM from, and demand a replacement.
Always buy genuine RAM from well known companies.
#krow @ irc.freenode.net
Cool Joe is offline
Old 13-10-2008, 06:19 PM   #3 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
there looks like the shopkeeper tricked you else your module should have worked well on other pcs with different moterboards....
Sooraj_digit is offline
Old 14-10-2008, 03:45 AM   #4 (permalink)
Point Blanc
its not getting tricked necessarily, the shopkeepers either does not sells much of computer parts maybe.
return the memory stick and ask him to give you another stick which is really 512MB, had happened to one of my frnd, but he was doing the checking in shop so did not bought it. The shopkeeper had got the RAMs from somewhere, but they were actually 128MB and 64MB, so no buying from there, latter I bought 512 SDRAM from SP Road and got it in 500 bucks whereas the previous shopkeeper was quoting something like 1K for one stick, I bought 3 sticks I think
acewin is offline
After Installing additional 512Mb DDR 400 RAM I dont find any increase in speed? Dongay Rajasekhar Panda Hardware Q&A 8 27-07-2008 10:12 PM
Problem installing SP2 ahamednms Software Q&A 12 14-07-2006 08:41 PM
installing problem noblefriend2002 QnA (read only) 3 20-01-2005 01:06 AM
