| Forum |
#1 (permalink) |
I have a problem. I have a old PC and now I want to buy a new one.. I was wondering what motherboard, processor and graphics card I should go for. Old PC configuration: P4 845 Pro motherboard NVIDIA CARD 2 IDE Hard disc (120GB & 160GB) 2 Writers(DVD and CD-ROM) My problem is that now the motherboards come with SATA connections.. I wanted to know any motherboard which best suits my need and which easily allows me to connect the 2 IDE HDD and 2 IDE WRITERS so that I can reuse my peripherals. I want the 160 GB HDD to be Master HDD and 120GB to be Slave. also I want the DVD Writer to be Master and CD Writer to be Slave. Also a advice for processor and Graphics card would be appreciated. Thanks a lot |
#3 (permalink) |
EXIT: DATA Junkyard
<No budget>
1. MSI P45NEO-F @ 5.8k 2. E7200 @ 5.4k 3. Palit HD4850 @ 9.3-9.5k
http://pleaseguide.me/ |
#4 (permalink) |
Excessive happiness
How could he ask for help w/o mentioning his budget....
Then its the config QX9750 Intel SkullTrail 3 X GTX 280 or 3 X HD4870 X2......
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ Addicted to Game Dev & Grand Prix Story |
#5 (permalink) |
EXIT: DATA Junkyard
QX 9770^^^
@ entire post lolol
#7 (permalink) |
EXIT: DATA Junkyard
lol, this is what happens, when people make it difficult for us with their incomplete info
Some dun do it purposedly (maybe once or twice) but some dun make an effort to remember, and that's when it becomes a pain in the ar$3
#8 (permalink) | |
Excessive happiness
Thats what he is doing... I am not blaming him.. Just ask him to provide the necessary info tat we need to help him....
#9 (permalink) |
EXIT: DATA Junkyard
^^appreciated..now we'll hav to wait(hehehe)
#10 (permalink) |
Ok..
I thought of a good config PC.. Now question that comes next is I want to purchase a Cooler Master Elite 331 model PC CASE, and I want to use a iball 400W SMPS.. The PC CASE has a 120mm fan. Will this SMPS support the 120mm fan in terms of power supply for the fan to work.. and also if I think of adding a Geforce 8500GT graphics card, will I need a seperate power supply for the graphics card? |
#11 (permalink) | |
Excessive happiness
BTW dont get iball SMPS if u wanna add a gfx card later... Next imp thing is,Dont get 8500GT... Its waste of money.. Instead of this go for 8600GT which comes around 3k....Best VFM...... Get Zebronics 500W SATA-II PSU......
#12 (permalink) |
My budget is Rs. 30000
by the way... the power supply for the 120mm fans comes for the power supply unit... Does the +12V rails supply power to the fan if use Zebronics 500W ? and If I use a iball SMPS (already have one), from where will the 120mm fan get the input power for it to work? Which is better Zebronics or Cooler Master Extreme Power power supply units? Last edited by fran1234; 14-10-2008 at 02:29 PM. Reason: Automerged Doublepost |
#13 (permalink) |
Excessive happiness
C2D E7200 - 5.8k
MSI P35 Neo F - 5k 2GB DDR2 - 1.8k XpertVision 9600GT - 5.5k Cabinet ur choice PowerSafe 500W Silver PSU - 1.7k ViewSonic 19" - 8.6k Logitech Combo - 0.8k 160GB WD - 1.8k It comes around 31k.... I assume that u need all the parts and so i give this config to u... If u want only CPU+Mobo+GFX Then E8500 MSI P45 Neo F HD4870....
#14 (permalink) |
Actually I thought of
intel c2d 3.0Ghz processor @8.2K intel dg31pr mobo @3.4K 19" LG TFT monitor @8.7K 2x1GB Transcend DDR2 800Mhz @ 1.9K lite on DVD-RW @1.3K Cooler Master Elite 331 PC CASE Cooler Master Extreme Power 460W I want to use my old (just 6 months ) 2 IDE HDD and APC UPS and also Keyboard & mouse. What about speakers? 2.0 or 2.1 channel ? Logitech? Creative? or some other Speaker budget upto Rs.1200 any replies?? Last edited by fran1234; 14-10-2008 at 03:09 PM. Reason: Automerged Doublepost |
#15 (permalink) | |
Excessive happiness
Dont buy Intel Mobos, unless ur in real shoestring budget Instead of LG, go for ViewSonic to save some bucks... Altec Lansing BXR Model 2.1 speakers will be good..(I forgot the model no)
#17 (permalink) |
At Hell's Disq
the E8400 is a 3GHz proccy (at stock speed
E8500 -> 3.16GHz E8600 -> 3.33GHz just 4 the info if any1 of ur getting any1 of the above procies plz do make sure that they r of the E0 stepping and not the old C0. the E0's oc better at lower vcores,have a few xtra instructions sets (nothing which sud promt u to sell ur current procy).
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#19 (permalink) |
Which 17" or 19" TFT monitors are the best ( w.r.t Performance and life) igroring the price factor.
LG Viewsonic Samsung or any other (please name them) And can I put a iball 400W SMPS temporatily for a Cooler Master Elite 332 or 331 PC CASE, cause I wanted to buy a Power supply and Graphics card later on, not now. One more reason is that I have 2 IDE HDD and i'll buy a SATA DVD-RW. But will iball 400W SMPS support the Intel DG31PR mobo, intel C2D 3.0Ghz processor, Cooler Master Elite 332 or 331 PC case fan? |
#20 (permalink) |
Point Blanc
bro think hard and if you will realize good proccy with ultra low-end mobo is a waste.
Dell 198WFP is good 19 inch monitor. Hence buyout MSI P35 Neo-F not Neo-F Combo in 4.3-4.5K is better go. Put any gfx card of your wish. Buy a low-end gfx card Asus 8600GT 256 MB DDR3 in 2.8K If you think its high to spend on the mobo + gfx card then better get E7200 than E8400 to keep the price balance. But if you think of DG31 chipset mobos then you do not wanna keep your system for very long. |
#21 (permalink) |
EXIT: DATA Junkyard
Biostar i45 @ 4.5k
E7200 @ 5.4k ViewSOnic 1916wm 19" TFT @ 8.6k 2*1GB DDR2 800MHz @ 2k 9800GT @ 7.5k Mind you, prices are rising at a very sharp rate!
#22 (permalink) |
I dont want to connect a Graphics card now.
Does iball 400W SMPS support intel DG35EC mobo, intel C2D 3.0Ghz and Cooler Master Elite 332 PC CASE. Can they be connected together without any problems? From where does the 120mm PC CASE fan get the power to put the fan on(using the SMPS) ? |
#23 (permalink) | ||
chilling..... |
#24 (permalink) | |
EXIT: DATA Junkyard
Okay 400W, u dun wanna connect gfx card now, u wont be able to later too, with tht PSU
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Motherboard for AMD | pramodv1988 | Hardware Q&A | 19 | 22-11-2007 09:06 PM |
| motherboard for AMD 64 | subhayu | Hardware Q&A | 2 | 20-12-2005 07:30 PM |
| Motherboard | godsownman | CPU / Motherboards | 4 | 16-06-2005 04:08 PM |
| Help!! I don't know my motherboard!! | abhi_shake | CPU / Motherboards | 4 | 18-03-2005 09:19 PM |
