| Forum |
#2 (permalink) |
life is short..be happy
Ur processor architecture should be x64-64Bit
For more see these articles:- http://en.wikipedia.org/wiki/X86-64#Intel_64 http://en.wikipedia.org/wiki/Windows...al_x64_Edition
Digit Tutorials Index | Digit Toolbar | Official I5801 Thread Worried about privacy?use DuckDuckGo! ! |
#3 (permalink) | |
xp_64 bit will work fine ..
chilling..... |
#4 (permalink) |
Searching for Anti-Matter
Ur chispet - 946GZ supports 64 bit computing and all the C2Ds are 64 bit proccies.
In Short ur system is 64 bit system but installing a 64 bit OS makes sense only if u have ram more than or 4 GB. 64 bit system means that the address and data buses are 64 bits wide and u can access(theoretically) 2^64 bits ~ 128 GBytes + of ram and thats insane amount of ram!
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ... |
#6 (permalink) |
The Smaller Bang
shortest answer: works
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#8 (permalink) | |
no its not needed its just that if RAM is more than 3Gb it doesn't get recognized by 32 bit OS ...so if u have say 4GB RAM ...windows xp 32 bit and vista 32 bit will only recognize only 3 GB ... but to run 64 bit u don't need 4GB works fine even with 1Gb RAM .. for vista obviously u will need 2Gb RAM to let it run smoothly ..
chilling..... Last edited by imgame2; 11-10-2008 at 07:14 PM. |
#9 (permalink) |
Violent serenity.
NOT NEEDED....... 4GB RAM requires 64Bit OS to work on full potential not the vice versa
Registered pwner of theists, noobs, posers and emos. |
#11 (permalink) | |
The Smaller Bang
#12 (permalink) |
Violent serenity.
^^I am talking natively.
And both are not wrong. 64Bit OS can work with 512MB RAM too
#13 (permalink) | |
even if u have 128MB ram winxp x64(Vista won't) will work fine but does not make any sense! Since u will be using 3 gig of ram u can go with 64 bit OS - in case if u want native OS support to run 64 bit apps. I think u must go for 64 bit OS for the sake of 64 bit apps!
#14 (permalink) |
U wont get real time speed & multitasking benefits with x64 until you are using 4Gb & above ram.
In x64 OS each software (assuming they are 32bit)can minimum use full 2gb ram, so the real benefit will be when you need to have 2-3 software making use of full capacity (2gb each)for which you would need above 4Gb of ram. Of course x64 will work in crawling mode on 512mb of ram (x64 Vista would require at least 2gb with a decent graphic card) I run 3 application which are x64 & each one of them is capable of using full 4gb & above if available so thats the real benefit of x64. Another things to consider is that you wont be running 3gb in dual channel mode, either it should be 4gb or 8gb (correct me if I am wrong)
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. |
#15 (permalink) | |
and i did not understand ur 4Gb for 64 bit theory ..so far with 3Gb on 64 bit i don't face any problems
chilling..... |
#16 (permalink) |
A LOTR fan
am using 2gb on vista x64, no problems...i dont think it will slow you down if you have anything less than 4gb.
it certainly did not slow me down.
How many kilometers are there from washington Dc to Miami beach?????.... unban praka123!!!.... |
#17 (permalink) | ||
Vista x64 OS in my case can hold & make use of 1.5gb of ram I can reduce the startup applications & bring it down to minimum 800mb of ram, so when i have 2 applications running & both using the dual cores & needing ram allocation, both the applications can use all the ram. That benefit is greatly reduced if you have 2-3gb ram bcoz then you can use it within a 32 bit system too , why do you need x64. x64 is like having 128 pipes coming to ur bathroom to fill the bucket & if all those pipe will outlet water from a only 2-3 taps then u r greatly loosing on it, u r better with 2 pipes to start with. Real benefit will be to have more outlet taps so u can fill a single bucket faster with multiple taps or fill more buckets together at the same speed /same time. Hope the above makes some sense, I myself was confused to go x64 or not as I was hitting bottlenecks when multi tasking on 32bit then i had to read a lot to understand how to get maximum out of a x64 & now i can do multitasking (4-5 intensive task without any slowness) I also tested a x64 vista 16gb ram (4gb x4 sticks & believe me it flies like a rocket when multitasking ) my next machine will have 12-16gb ram when photoshop x64 bit CS4 is launched. There are 7 application now which I need to use & they are x64 so they can use all the available (no 2gb limit) ram.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Requirements for ATi HD4850!!! | george101 | Hardware Q&A | 36 | 24-12-2008 09:52 AM |
| Recommended Requirements!!! | Zangetsu | Gamerz | 6 | 04-04-2008 04:17 PM |
| Vista Requirements plz | shashank_digitreader | Software Q&A | 6 | 17-10-2006 06:05 PM |
| Requirements for AOE3? | shashank_digitreader | Gamerz | 4 | 03-09-2006 07:50 PM |
| dvd requirements | android | QnA (read only) | 4 | 03-11-2004 12:27 AM |
