Old 10-10-2008, 11:33 PM   #1 (permalink)
Simpsons rox
Default does 22" monitor require gr8 graphix card?
so i currently have a 17" crt monitor and a nvidia 6200 graphix card.
now i can play hd movies upto 720p without any problem.
now if i buy a 22" or 24" lcd monitor then will i be able to run movies and the games that i play now without any problems??
mainly read text,net and movies.
mainly for movies i want to buy the new monitor.
T.G. Praveen
A computer program does what you tell it to do, not what you want it to do.
Visit my site at www.praveen.co.nr
tgpraveen is offline
Old 11-10-2008, 05:08 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: does 22" monitor require gr8 graphix card?
well, the reso. is usually 1680x1050 or 1920x1200 for 22" and 24" monitors.
And let me say, 6200 and gaming are two separate galaxies..
+ on a 22" monitor, forget it.
Upgrade to a 8600GT for movies and okay gaming(8500GT or 9400GT if only for movies)
http://pleaseguide.me/
comp@ddict is offline
Old 11-10-2008, 09:01 PM   #3 (permalink)
Intel OCer
amitash's Avatar
Yes it does if u plan on gaming alot
My site: collegeclassroom.org
amitash is offline
Old 11-10-2008, 09:53 PM   #4 (permalink)
Simpsons rox
well like i said i use mainly net ie text and the reason for upgrade is for better movie viewing experience.
so will i be able to do this smoothly on a 22" or 24" screen and with this nvidia 6200 card.
whereas gamess are concerned well i mostly play 2 yrs or more old games rihgt now so will they run on the new monitor?
T.G. Praveen
Old 11-10-2008, 10:12 PM   #5 (permalink)
i doubt that cos with 22" u will have increased resolution and many old games will not work so smoothly with higher resolution u might have to play them at old resolution u used to play ...
but still i would suggest u to go for 8600 gt or similar ..if not now then may be after some time
chilling.....
imgame2 is offline
Old 11-10-2008, 10:27 PM   #6 (permalink)
The G-Axe Effect
gxsaurav's Avatar
You won't have any problem buying a new Monitor. You don't need a new graphics card. However tell me these
1) How much RAM your graphics card has
2) Do U use Vista?
The thing is, Microsoft recommends a graphics card with 256 MB or More of RAM if you are going to use resolution of 1600X1200 or above on Vista with Aero. With a 20 or 22" Monitor, these are common resolutions. if you use Windows XP then even 128 MB of RAM in GPU will do.
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 11-10-2008, 11:52 PM   #7 (permalink)
Ethan_Hunt's Avatar
Movies would scale fine but the games won't.If you plan to play any game on a 24 inch below it's native resolution then it would look pathetic (So I've heard).Considering your current graphics card I doubt it would pull any games about 800x600 resolution (depending on the game you play).Rest assured the movies would look brilliant.Better opt for a Dell monitor.
V for Vendetta
Ethan_Hunt is offline
Old 12-10-2008, 12:57 PM   #8 (permalink)
Simpsons rox
256 mb ram on graphix card
and i use only xp and ubuntu.
T.G. Praveen
Old 12-10-2008, 01:02 PM   #9 (permalink)
A LOTR fan
x3060's Avatar
good enough, you will be able to watch movies, and do doc works, while playing games reduce the res....thats all
How many kilometers are there from washington Dc to Miami beach?????....
unban praka123!!!....
x3060 is offline
Old 12-10-2008, 01:11 PM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Just get 8600GT or 9500GT, and u'll get light(as air) gaming and no probs in movies
Graphix Card Purchase Help rohanb Hardware Q&A 2 03-07-2007 09:45 PM
Help Re:Graphix card and Motherboad. REY619 Hardware Q&A 4 14-10-2006 08:01 AM
PCI graphix card support query cooldip10 QnA (read only) 1 17-05-2006 08:10 PM
PS2 Vs XBOX Vs New Graphix Card. mojojojo Gamerz 24 12-11-2005 06:43 AM
Graphix Card Issue speedyguy QnA (read only) 7 28-06-2005 01:48 PM
