Old 10-10-2008, 12:52 PM   #1 (permalink)
Default Which is best MOBO for AMD 4400 & 5200?
Sir,
Q.1. I want to buy a Budget MOBO (within Rs.3000) for AMD 4400+ & 5200+ processors with onboard graphic card.
The MOBO should be with onboard Graphic Card and should be such that it can be upgraded with putting a graphic card in future.
Q.2. Can the mobo & above processor if used together can be overclocked?
Q.3. Are there any dangers of overclocking?
Rest of my configration for both the computers is :
RAM: 2*1GB Transcend DDR 2 : Rs.1750
HDD : Hitachi OR Segate Sata 2 320 GB (16 MB Buffer) : 2600
Lite On 20X DVD Writer with Light Scribe : 1200
Zebronics Bijli : 1650
Q.4. Your views on the above configration?
LASTLY GIVE YOUR SUGGESTIONS
My budget for the above CPUs is Rs.9000/- & 11000/-
Regards
Rohitshakti_sehgal@yahoo.com
rohitshakti2 is offline
Old 10-10-2008, 01:23 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Which is best MOBO for AMD 4400 & 5200?
Above CPUs??????
What u want the entire PC for 10K!!!!!!
http://pleaseguide.me/
comp@ddict is offline
Old 10-10-2008, 03:17 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
lol.... his post is quite confusing.
Psychosocial is offline
CREATIVE INSPIRE 4400 Front/Rear Sound??? modern_crusader Software Q&A 4 23-05-2006 02:51 AM
XFX 5200 compatible with my MOBO? Aseem Nasnodkar CPU / Motherboards 9 19-06-2005 02:43 PM
Creative Inspire 4400 problem mohit QnA (read only) 8 03-03-2005 12:56 AM
