Old 10-10-2008, 10:59 AM   #1 (permalink)
Default HDD not detected on one pc, detects on others..
Hi,
I recently bought a Seagate 500gb HDD.
I have two pcs one with an ASUS M2N-E MB and one with a Asrock 939A8X-M MB. The Asus mb supports 3gb/s, the Asrock doesnt. When i try my hdd on the asus mb it detects fine in the bios, but when i try it on the asrock mb it doesnt detect at all, even on 1.5gb/s transfer mode. I bought the asrock mb 3 months ago, so i really doubt its an outdated bios. Any advice?
Slips is offline
Old 10-10-2008, 12:07 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: HDD not detected on one pc, detects on others..
just check with the mobo manual of asrock 4 HDD connectivity & compatibility
wats ur HDD...SATA or SATA2
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 11-10-2008, 05:35 AM   #3 (permalink)
Sata 1, if by sata1 you mean transfer rate, which is 1.5gb/s on my asrock mb.
Slips is offline
CA eTrust antivirus detects Windows as malicious... anandk Technology News 1 06-09-2006 12:12 PM
Alcohol 120% doesn't detects combo nishant_nms Software Q&A 4 17-01-2006 02:57 PM
win 98 not detecting cd rom drive. dos and xp detects it aditya169 Software Q&A 24 24-06-2005 08:16 AM
