| Forum |
#1 (permalink) |
I want an external TV tuner Box which I can use on my 19" LG LCD Monitor without switching on the PC. However I want to record TV programs whenever I want by switching on the CPU (via USB port). I hope external TV tuners with both VGA out & USB interface should be available. I searched a lot but couldn't find a qualifying product, Pls help me finding the exact model. Thank you.
No Terms : Just One Condition |
#4 (permalink) |
At Hell's Disq
afaik theres no xternal tv tuner available which supports both vga and usb.so wat u've planned is not exactly possible.
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#5 (permalink) | ||
Point Blanc
Check Pinnacle 50e, I had used a USB TV Tuner from UMax (cost 1800) had good quality and alright recording. What do you mean by VGA out & USB interface. Last edited by acewin; 11-10-2008 at 01:28 AM. Reason: Automerged Doublepost |
#6 (permalink) |
By VGA Out : I mean I can connect to any CRT/LCD Monitor without switching on PC.
By USB interface : I mean the same external tV tuner should have a optional USB interface which may stream video to PC for recording whenever required.
#7 (permalink) |
The High 5 Flyer
why do you want to stream to PC via USB, you can do the same via VGA splitter, so both your TV and PC monitor are on VGA. Then you can use your PC with any good PVR (pinnacle is good) software to record shows.....
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| External TV box capture | stellar | Software Q&A | 2 | 10-03-2007 11:30 AM |
| cannot capture picture in tv tuner card | bkpeerless | QnA (read only) | 1 | 27-07-2006 09:19 PM |
| Suggest better TV capture tuner | steelwin | Hardware Q&A | 12 | 04-04-2006 06:45 AM |
| Which Codec To Capture Video From TV Tuner Card | abhinavrakesh | Software Q&A | 3 | 22-02-2006 08:49 PM |
