Old 09-10-2008, 01:37 PM   #1 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default INTEL's recommendation
Hey guys,
When I started my PC it didn't move on after the bio screen(1st screen that comes).
There was my mobo and blah blah...and then, in the end there was this written:
"Intel recommends the use of a 2x12 power connector OR a 2x10 power connector in conjugation with the 1x4 alternate power connector."
This has really freaked me out. What is this? And after that was written
"Press any key to continue"
When I do so it goes on to oad the OS and normal startup.
My config is:
P4 3GHz HT
Intel D915GAG
XFX 6200TC
1GB DDR 400MHz + 512MB DDR 333MHz = 1.5GB DDR 333MHz(400MHz scaled down)
250W SMPS
My config has given no such messga efor the past 3 years..Then why now?
And there has been no affect in performance.
What is the problem?
http://pleaseguide.me/
comp@ddict is offline
Old 09-10-2008, 10:59 PM   #2 (permalink)
harryneopotter's Avatar
Default Re: INTEL's recommendation
the problem is of power shortage ...... the line at the end of the message is refferring to the 24 or 20 pin power connector with a seperate power 4 pin power connector (placed near by the back plate and proceesor.)
May be one(or more) pins in ur PSU's power supply connecters have gone bad.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 10-10-2008, 01:09 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Thnx..hasn't come again..I'm okay for now...
Old 10-10-2008, 04:19 PM   #4 (permalink)
mad_max's Avatar
omg dude at what rate do you post awsum ****
oh your psu is slowly starting to kick the bucket,get a new one before it drags the who system down with it
thats sh*t lol
mad_max is offline
Old 10-10-2008, 10:31 PM   #5 (permalink)
no need to say thanx dude ... thats wat we are here for, isnt it ??
Y ??
Old 10-10-2008, 10:37 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Understood...will try to kep the computer frm crashing(tumbling too) till nxt march then will go for full upgrade
Recommendation for basic phone with excellent reception and battery life jingalala Mobiles and Tablets 5 02-10-2008 03:08 AM
Recommendation for a good mp3 player sohancool Software Q&A 6 26-08-2008 09:48 PM
AGP recommendation gr8usr Hardware Q&A 5 16-12-2006 11:03 PM
