08-10-2008, 06:02 PM
An Esoteric Geek
Planning to buy a 22" monitor
Hi Folks
I am planning to buy a 20" or 22" monitor. I am from Bangalore.
I have some specifications. My budget is 15K.
1. DVI-D is required
3. SVideo and Composite input, HDMI(Optional)
4. Typical Contrast Ratio of 1000:1
More or less, I need a Monitor TV.
I Know I am very greedy about specifications for such price. Is there any such monitor available at my budget? Please also suggest where in Bangalore could I get such monitor.
Regards
Sridatta
Reason: Removed Speakers in my specs
08-10-2008, 06:36 PM
Re: Planning to buy a 22" monitor
for 22"
this is the best u can get
dell SP2208WPF for 16.5k ..doesn't have inbuilt speaker though ..if u want to watch Tv still get separate speakers ...monitor speakers won't be good anyway..
or dell E228WFP 22" for 14.5k
or get viewsonic 2262wm/wmp for about 13.5k or 14k (don't know the exact price) someone bought it few weeks back at that price ...may be but i m not sure ..about the price
it has everything u need ..
chilling.....
08-10-2008, 07:21 PM
An Esoteric Geek
thanx for the reply..
I could not find any monitor with such model numbers in Dell.co.in site. They might have updated the models.
Suggest me the equivalent model..
08-10-2008, 07:40 PM
they are very much available in india and many people have bought it ...
here check it out
http://www1.ap.dell.com/content/prod...hs1&l=en&s=dhs
chilling.....
08-10-2008, 08:14 PM
An Esoteric Geek
There are no monitors in my budget range which meet my specs. I need a monitor with Composite and SVideo. Only two monitors with such pins are priced 20k and 49k..
Originally Posted by imgame2
08-10-2008, 08:25 PM
Violent serenity.
Dell 228WFP is in your budget AFAIK.
08-10-2008, 08:28 PM
why do u need that ??
chilling.....
08-10-2008, 10:26 PM
EXIT: DATA Junkyard
JUst get the 'D'E'L'L' Monitor and make merry
09-10-2008, 12:07 AM
An Esoteric Geek
It doesnot have Composite video and svideo. So, ruled out!
I can actually get a 22" Benq Monitor with 5ms response time, 1000:1 typ contrast ratio, DVI-D port for 10.5k. What I am looking is a multimedia monitor.
09-10-2008, 12:12 AM
Point Blanc
dude, all the Dell monitors have DVI port. S-Video is something specific for TVs.
So get real, you need a computer monitor or a TV. you can use TV as system moitor also.
09-10-2008, 12:17 AM
An Esoteric Geek
Because I want to connect my set-top box directly to my monitor without purchasing TV Tuner card. I just dont want to put TV and monitor seperately in my room..
CRT TVs have much lower resolution than monitors. AFAIK, LCD TVs are priced higher than a similar sized Monitor.
LGM228WA monitor is priced at 19.5k in LG's website. I am not sure if it is the dealer price or retailer price. Please also let me know any reviews on that..
Reason: Automerged Doublepost
10-10-2008, 04:47 PM
wahts so special about that monitor ..?? its look ??
it will be very costly i can assure u that much ...
chilling.....
10-10-2008, 05:52 PM
An Esoteric Geek
Yeah.. Looks are great.. and It has got all features I m looking for.. Composite, Svideo, Good Speakers with woofer, Webcam, USB Ports.. and good response time, contrast ratio.
I was not able to find the price in india though..
10-10-2008, 06:22 PM
why don't u go for that LG model LGM228WA ....this model of ASUS if at all available in india will cost near 20k for sure ...
locate a dealer on LG site and call them up ask for the price of that LG monitor ..i hope it comes around 15k
chilling.....
10-10-2008, 08:01 PM
prabhu.wali
i'd recomend DELL SP2208WPF ,itz been a month o so since i've got it n belive me you won't be dissappointed thoug the price is little bit on the higher side bot u'll get an inbuilt webcam with it which offers a good clarity
11-10-2008, 04:02 AM
Point Blanc
duh, mate in that price you can easily buy monitor + TV Tuner card.
and tehre is something called HDMI and DVI port. And I hope Set Top Boxes with DVI port are available(until and unless you already bought one which has S-Video)
SP2208 has HDMI/DVI port so it can be used with any set top box with the ports.
get real man
Even the price of LG monitor, ingame suggested is around 20K
11-10-2008, 04:17 AM
Commander in Chief
Quality first, extra ports last! A TV-Tuner card doesn't cost much really.
Harsh J
www.harshj.com
11-10-2008, 11:42 AM
#19 (permalink)
^^^ +1 agree totally ....
chilling.....
13-10-2008, 11:43 AM
#20 (permalink)
An Esoteric Geek
agreed with all you guys..
I know I was a bit greedy.. but I tried to find one at a reasonable price.. but, with any model, i s'd compromise something or the other..
DELL SP2208 is a great model, but, I m looking for a black one.. Please let me know if black model is available..
The only thing I was worried about TV tuner card is the compatibility with LCD Resolution and Clarity..
The Asus PG221 which I was referring to.. costs 34K..  so.. dropped!!
13-10-2008, 12:00 PM
#21 (permalink)
Bond, Desi Bond!
You can't get diamonds for peanuts!!!!
Get Dell 2208WFP or 228WFP dude. You won't regret.
You can also check Viewsonic and AOC for black monitors. They won't perform or will not be as reliable as Dell or Samsung. Still, you may check those models.
BenQ has a 21.3" 16:9 FullHD model that is selling for some 14k. But you need a good graphics card to get the most out of it and a powerful graphics card to play games on it.
13-10-2008, 02:03 PM
#22 (permalink)
An Esoteric Geek
I have 8500GT graphics card
Are benq monitors reliable?
13-10-2008, 04:02 PM
#23 (permalink)
Caballero de Real Madrid
is benq available in stores?? AFAIK..they are not..
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
13-10-2008, 04:07 PM
#24 (permalink)
An Esoteric Geek
I found a dealer who can offer Benq T221 for 10.5 (including taxes)
It has got 1000:1 response time and 5ms response time.. But, still I donno if the monitor is good..
13-10-2008, 04:16 PM
#25 (permalink)
Fullbring
Y dont u purchase the recommended DELL model & then paint it 2 black
13-10-2008, 04:39 PM
#26 (permalink)
An Esoteric Geek
Good PJ.. nice try !!
13-10-2008, 05:38 PM
#27 (permalink)
Bond, Desi Bond!
actually, why do you want to sacrifice monitor's performance just for the bezel's color??
13-10-2008, 08:53 PM
#28 (permalink)
An Esoteric Geek
guys, I found two different models with very much similar model name..
Dell UltraSharp 2208WFP
and Dell SP2008WFP
Though, I couldn't find the first model listed in India site.
I know Dell's clarity is very good. I work on 2 * 24"(2408WFP) DELL monitors in office. I am used to such big screens.. I always feel like Dell monitors only suit for office use and lacks style..
14-10-2008, 03:48 AM
#29 (permalink)
Point Blanc
interestingly when I called up Dell, they said me E2208 is EOL now, and the saleperson said they are not selling it.
21-10-2008, 09:34 PM
#30 (permalink)
@sridatta
Go for Dell SP2208WFP. I got it nearly 4 months ago and the set just looks amazing. One of the best screens that I have seen. I wanted a black bezel, but checking on the specs this set offers, I had to compromise on the bezel colour. Believe me, you wont regret buying this silver bezel. The sides of the bezel and the base are black and the combination looks elegant. 2ms response makes a good difference when you are watching a movie. And if you consider the camera on it, 2MP webcam with stereo speakers is surely an added adv. And warranty of Dell is incomparable. >6 dead pixels in 3 years and the set will be replaced. With HDMI and DVI cinnectors this is the best set in the market at 16,100/- all inclusive and delivered at home (you may try to bargain a bit more if it permits).
Check any thread on SP2208WFP for more comments.
Core2Duo 8400 (3.0GHz)
Abit IP35Pro MoBo
XFX 8800GTS 512MB Alpha Dog
Patriot 1+1GB 800MHz RAM
250GB SATA HDD
CoolerMaster Cabinet & SMPS
Dell SP2208WFP 22" monitor
Microsoft Sidewinder mouse
