Old 08-10-2008, 02:11 PM   #1 (permalink)
Default System freezes......
system freezes and a blue screen appears and ma system restarts? wat's the actual problem?
AYmn is offline
Old 08-10-2008, 02:37 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: System freezes......
Driver conflict/corrupt driver. Thats the actual problem. Post your HijackThis log. Of course it can be due to bad memory too.
dheeraj_kumar is offline
Old 08-10-2008, 03:39 PM   #3 (permalink)
so wat can i do to solve this problem?
IT'S showing the error message
Technical informationj:
0x0000007E(0xc0000005 x 0xF89FD060 X OXF89FCD5C)
AYmn is offline
Old 10-10-2008, 07:53 AM   #4 (permalink)
if u have installed any new hardware drivers try uninstalling and reinstalling them
if not clear your page file of C:\ Drive some times the virtual mem problems also giv such messages
blacrobous is offline
Old 10-10-2008, 07:58 AM   #5 (permalink)
so how can i solve this problem?
AYmn is offline
Old 10-10-2008, 08:01 AM   #6 (permalink)
reinstall all drivers again from your mobo CD
Old 10-10-2008, 08:02 AM   #7 (permalink)
mobo cd?wat's tat?
i doesn't have motherboard cd
AYmn is offline
Old 10-10-2008, 08:03 AM   #8 (permalink)
Motherboard Drivers CD + your nvidia gfx driver Cd install these both
Old 10-10-2008, 08:06 AM   #9 (permalink)
i lost my motherboard cd........so wat can i do....
AYmn is offline
Old 10-10-2008, 08:09 AM   #10 (permalink)
first install graphics card driver bro then lets think of motherboard if it doesnt work
System freezes during browsing windchimes Software Q&A 4 01-04-2008 08:03 PM
My System Freezes :-( sysfilez Software Q&A 5 12-10-2006 02:41 PM
my system freezes . urgent amargupta Software Q&A 10 04-08-2006 11:01 PM
My system freezes suddenly mousereddy Hardware Q&A 2 27-10-2005 07:38 PM
AMD System freezes too much!! armourlength Software Q&A 10 06-06-2005 05:04 PM
- by kool
