Old 07-10-2008, 07:36 PM   #1 (permalink)
Default Help needed with this "Disk Boot Failure" Error Msg
Hi all,
I got this msg "Disk boot failure" after i replaced my old motherboard with a new gigabyte motherboard. Do i need to install a fresh os or i need configure the bios?
Plz help me to solve this issue
sharan_sri is offline
Old 07-10-2008, 07:47 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help needed with this "Disk Boot Failure" Error Msg
Reconfigure the bios. Specifically, change the boot order.
dheeraj_kumar is offline
Old 07-10-2008, 07:49 PM   #3 (permalink)
i have also set the primary boot device as Hard disk. But still the error occurs
Old 07-10-2008, 10:08 PM   #4 (permalink)
may b the hard disk not connected properly
or the hard disk got corrupted
thinkhatke is offline
Old 07-10-2008, 10:22 PM   #5 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Check in BIOS whether hard disk is detected or not.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 08-10-2008, 03:10 PM   #6 (permalink)
Originally Posted by sharan_sri View Post
Hi all,
first check BIOS if HDD is detected ...if its there then there is no problem with HDD and if u still get the same error message u will need to install the OS again ...cos OS doesn't know ur mobo is changed
chilling.....
imgame2 is offline
Old 09-10-2008, 07:24 PM   #7 (permalink)
I have repaired the XP OS and my system boots but only with the help of OS CD. I tried to boot xp w/o the OS cd but ended with same error msg "DISK BOOT FAILURE, INSERT A START UP DISK",Also my motherboard takes much time to get past the devices listing (almost 5 mins) and finally it asks "boot from cd:" and then boots up
Disk Boot Failure. Urgent Help needed ! Dark Star Open Source 12 06-01-2008 05:43 PM
"Disk is write protected" error shady_inc Hardware Q&A 11 31-10-2007 10:54 PM
"Hard disk Failed Press H to retry or enter to boot from other device " uzair Hardware Q&A 7 01-04-2007 12:33 AM
Windows cannot find "rose.exe" error, when accessing Hard disk drives ! vishesh8 Software Q&A 14 11-01-2007 10:01 PM
- by kool
