Old 07-10-2008, 06:57 PM   #1 (permalink)
Default Budget HTPC
Hi..i want to build a budget HTPC. My budget is 7000. Only suggest cpu,motherboard,ram and graphics...everything else i hv. Please reply as soon as possible.
By Regards,
Amey.
amey_dude is offline
Old 07-10-2008, 07:20 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: Budget HTPC
Intel Dual Core E2160
ASUS P5GCMX (has onboard grafix)
1GB DDR2 667MHz RAM
-->Totals to exactly 6000/-
And there are cheap grafix card available like XFX 7200GS 256MB for 1300/-. You can buy if you wish to but onboard will be enough IMHO.
Psychosocial is offline
Old 07-10-2008, 07:31 PM   #3 (permalink)
any amd setups ??
By Regards,
Amey.
Old 07-10-2008, 09:58 PM   #4 (permalink)
Violent serenity.
hmm......why not ?
AMD Athlon 64 X2 4600+
ASUS M2N MX-SE (has onboard grafix.....6150SE from NVIDIA)
1GB DDR2 667MHz RAM
--> Totals to 5875/-
For the grafix, my suggestion remains the same.
Old 08-10-2008, 01:10 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
E2140 @ 2.5k
Transcend Value 1GB DDR2 667MHz @ 0.7k
MSI G31 @ 2.5k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 08-10-2008, 01:46 PM   #6 (permalink)
Violent serenity.
Originally Posted by comp@ddict View Post
E2140 @ 2.5k
MSI G31 @ 2.5k
Actually the Intel config I gave performs better than this as it has E2160 BUT yours has a G31 IGP which is better than 945 IGP .
Old 08-10-2008, 02:43 PM   #7 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
For AMD, get atleast Zotac GF8200 for 3.4K if you want HD video decoding. I doubt your 6150 can do HD.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 08-10-2008, 10:09 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yes...and 2140 can be upped(OCed) to 2GHz easily(if not 2.5GHz) even by a newbie..
so aftr that..onboard sloution dependent
About me:
Old 08-10-2008, 10:22 PM   #9 (permalink)
Violent serenity.
Yup.......so go for comp@ddict's setup .
My HTPC - the long brief Ponmayilal Reviews 39 21-04-2008 07:13 PM
HTPC configuration sarulan PC Components / Configurations 3 18-11-2007 11:49 AM
HTPC Query Charan Hardware Q&A 16 06-10-2007 06:19 PM
Budget HTPC case ??? DigitalImmigrant Hardware Q&A 1 16-06-2007 11:09 AM
HTPC suggestion hitman050 Hardware Q&A 1 19-05-2007 12:45 PM
- by kool
