Old 06-10-2008, 08:04 PM   #1 (permalink)
Default Suggest A nice budget upgrade
guys i need to upgrade my pc since i use many 3d applications like autocad 2009 and CATIA etc.. and even some games
my budget is 20,000rs
the upgrades to be done are
1.) motherboard
2.)graphics card
3.)PSU
4.)hard disk
5.)Processor
i hope it will come in this budget or else please even tell me for 25,000rs.
blacrobous is offline
Old 06-10-2008, 08:25 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Suggest A nice budget upgrade
1.MSI p45 neo-f-5.9k
2.Palit 9600Gso-5.8k
3.CM-500W-2.6k
4.segate 250GB/500GB
5.intel E7200-5.5k
My site: collegeclassroom.org
amitash is offline
Old 06-10-2008, 09:02 PM   #3 (permalink)
can u tell me where can i buy this products from
and how much is the price for seagate 250Gb
Old 06-10-2008, 09:10 PM   #4 (permalink)
1.) motherboard
2.)graphics card
3.)PSU
4.)hard disk
5.)Processor
in that price range u can't get a decent qudro fx card which is very essential for softwares u are using ..otherwise complex models will take a lot of time to render ...u need to buy a powerful gfx card or a good quadro fx card or firegl card ..
chilling.....
imgame2 is offline
Old 06-10-2008, 09:12 PM   #5 (permalink)
but those quadro fx cards are too costly even costlier than some of my softwares if you can suggest some good ones in this budget it would be helpful for me
Old 06-10-2008, 09:17 PM   #6 (permalink)
there is nothing u can get in this budget that will do u any good ..they are costly ..but they really render very complex models faster ..which is why they are costly ....
specially in CATIA..i don't know ur level of complexity ...but if u are pro ..it will take a lot of time ..
chilling.....
imgame2 is offline
Old 06-10-2008, 09:20 PM   #7 (permalink)
iam still a student for now so i aint into any complex models right now so which do you suggest would be nice for normal models i mean entry level
Old 06-10-2008, 09:38 PM   #8 (permalink)
u can go for a lower mobo and better gfx card that will benefit u more cos ur application is gfx oriented so a better gfx card will do the trick ..
intel E7200- 5.4k
asus P5K PL CM-2.8k or palit P35A = 4.2k
palit HD4850 - 9.7k
CM500W-2.7k or corsair vx450W for 3.2k
seagate- 2.6k
all comes @ 25k even if u choose palit P35A and corsair vx450W (which i will recommend u to choose)..and the performance will be much better if u choose 9600gt and MSI P45 neo mobo might give 5~ 7% better performance ..but for ur work this system will beat the system with 9600gt cos HD4850 is hell of a card...
chilling.....
imgame2 is offline
Old 06-10-2008, 09:48 PM   #9 (permalink)
wow! u guys sure rock i had a friend of mine suggested this forum and im really satisfied
but can u guys even tell me where can i buy them from because i donno much abt where these components are available
i live in hyderabad and thanks for the suggestion
Old 06-10-2008, 09:56 PM   #10 (permalink)
thanks about the good words for the forum ..and it rocks no doubt about that ...well there are many people from hyd ..and it looks like prices are on lower side in hyd ..u should try searching about the same in the forum...
but i have heard many people telling this name called bhumika computers ( i don't know where it is ) ...lots of people buy it from there ...
if u can't find anything look at online shops
http://www.lynx-india.com/
http://theitwares.com/
they are good and credible ..
and don't forget to tell us how ur system performs once u buy it ...
chilling.....
imgame2 is offline
Old 06-10-2008, 09:59 PM   #11 (permalink)
ya i know abt bhumika computers but never knew i could find components for an assembled system there
and yes ill sure tell how my system will perform thnxx again for the help
Old 06-10-2008, 10:54 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
2.3k...
watever happens..dun settle for less than HD4850 please
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 07-10-2008, 09:20 AM   #13 (permalink)
ya i ve read many reviews on this card seems like ATI is back on its track to beat the nvidia geforce series at last hope AMD takes its crown back
Old 07-10-2008, 12:09 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^u've heard rite my friend
About me:
Old 10-10-2008, 09:50 PM   #15 (permalink)
thnx guys i got all the things you suggested there except the mobo which wasnt available i thought of upgrading it again after few monthts till then i decided to use intel DG35EC
and my system runs like WOW! but the graphics card gets too hot donno how to cool it
Old 10-10-2008, 10:49 PM   #16 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Good ^^^
4850 runs hot
Use rivatuner and set fan speed to 80% to solve ur problem
About me:
A nice TV in 20K budget...!! prasad_den QnA (read only) 10 07-02-2008 02:49 PM
Plz help, for upgrade budget: 15~16k LoBo Hardware Q&A 17 15-06-2007 02:02 PM
Suggest a nice game... puja399 Gamerz 20 03-03-2006 09:49 AM
Plz Suggest upgrade for budget. Tommy Vercetti Hardware Q&A 4 06-12-2005 02:58 PM
- by kool
