Old 06-10-2008, 05:58 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default WD 640GB As External...
Hi Friends,
I am planning to buy WD 640GB HDD, I want to use it as internal as-well-as sometime external. I don't know will it be able to make external, and if yes wat will i need?
Thanks
Varad
VarDOS is offline
Old 06-10-2008, 06:19 PM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: WD 640GB As External...
Originally Posted by Varad Dilip Choudhari View Post
Hi Friends,
Thanks
Varad
Just get a External HDD Case and put ur HDD in it... Now 2-in-1 HDD....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Old 06-10-2008, 06:24 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
an external casing can u tell me which on 2.5" 3.5" 5.5"...
VarDOS is offline
Old 06-10-2008, 08:24 PM   #4 (permalink)
Point Blanc
I bought Coolermaster case. It is good and power adaptor is bes I have seen
little costly though SATA wud be around 1400 bucks
acewin is offline
Old 07-10-2008, 04:47 PM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
so i need a power adapter to connect it.... or simple USB might work.
VarDOS is offline
Old 07-10-2008, 05:52 PM   #6 (permalink)
Excessive happiness
Yes, u need a Power Adapter to make it work..(I hope so..) Coz the HDD has a power connector rite...
PS Request
Old 08-10-2008, 03:40 AM   #7 (permalink)
deathvirus_me's Avatar
Get a eSATA casing .. or u'll miss out a lot out on the performance ..
deathvirus_me is offline
Old 08-10-2008, 06:55 AM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
but can e-sata casing be connected by USB...
VarDOS is offline
Seagate 500GB or WD 640GB??????? george101 Hardware Q&A 20 02-08-2008 11:35 AM
External HDD chicha Hardware Q&A 2 14-10-2007 11:50 AM
external HDD chicha Chit-Chat 7 23-07-2007 05:04 PM
- by kool
