Old 05-10-2008, 11:53 PM   #1 (permalink)
Default PC hangs..after inserting CD in drive
Off lately I have discovered something…every time I insert a CD into the CD ROM Drive... the Hard disk and subsequently the entire PC hangs….the only option is the RESET key!
It’s LG DVD Writer. Win XP SP2.
The only way it now works is I restart the PC and before windows loads..insert the CD into the drive.
Any thoughts what is going wrong would be great...Thx.
patkim is online now
Old 06-10-2008, 12:13 AM   #2 (permalink)
sam_1710's Avatar
Default Re: PC hangs..after inserting CD in drive
i too have this problem on my LG DVD Writer (on vista) when i try the same disk on my Sony DVD writer it reads it properly!!
sam_1710 is offline
System hangs on inserting DVD chandru_skc Software Q&A 6 20-02-2008 01:05 PM
Hard Drive hangs after a clicking noise midhunmon Hardware Q&A 1 06-11-2007 05:37 PM
System hangs up wit floppy drive poping in.. speedyguy Software Q&A 7 15-07-2007 12:46 PM
System hangs when i try to access DVD drive madhu84 Hardware Q&A 6 13-09-2006 07:06 PM
PC hangs when inserting CD's lahratla QnA (read only) 7 05-07-2005 11:44 AM
- by kool
