Old 05-10-2008, 10:18 PM   #1 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Need help with PSP
Well I have a problem with my Memory Stick. Whenever I connect PSP to PC....Windows shows that you need to format the device. If I format the MS via Windows (in any format, FAT, exFAT, NTFS).....it states the capacity as 966kb (WTF)..I even tried formatting it via PSP...what shall I do ? I am on 3.71 M33-4 CFW.
Psychosocial is offline
Old 06-10-2008, 12:26 PM   #2 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Default Re: Need help with PSP
Yes it shows the msg , i just format it from there. I continue my work without formatting . Always format it with PSP. Never got into details of why this happens.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is online now
Old 06-10-2008, 12:37 PM   #3 (permalink)
Violent serenity.
Just checked my MS with Images>triangle>Information trick......its a duplicate .
Old 06-10-2008, 01:33 PM   #4 (permalink)
tarey_g's Avatar
get it replaced if you can.
but if its working fine, then well and good.
Windows 8 ? :lol:
Old 06-10-2008, 01:43 PM   #5 (permalink)
Violent serenity.
No, it aint working fine .....and its almost 9-10 months since I bought ...I have one 2GB MS and one 4GB MS.....the 4GB on is the duplicate...so today I will go and get a genuine one . Thanks for replying though coz whenever I have a problem and post it, no-one replies .
Old 06-10-2008, 03:36 PM   #6 (permalink)
tarey_g's Avatar
If you had posted it in this thread ,
PSP slim and Lite - My Review
many would have helped you. Almost all PSP owners of this forum visit it. Anyways, glad to help.
Windows 8 ? :lol:
- by kool
