Old 05-10-2008, 08:48 AM   #1 (permalink)
Default DVD writter not recognizing blank dvd's
It does read games pre recoreded DVD's ie Films, it reads dvd burnt on other machines and it reads all sorts of CD's. Wen i insert a a blank DVD of any kind the drive instantly turns from a DVD RAM into a cd drive on My computer. Any help anyone could suggest would be great and it show's Free space 0 and total size 0
my dvd writter is sony ad 7200s
AYmn is offline
Old 05-10-2008, 09:12 AM   #2 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
Default Re: DVD writter not recognizing blank dvd's
is turns to that only by default its no problem burn any data you want and then insert it will be working fine
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 05-10-2008, 09:29 AM   #3 (permalink)
But it is showing TOtal size 0 AND FREE SPACE 0 I tried 4 or 5 blank dvd's
AYmn is offline
Old 05-10-2008, 09:30 AM   #4 (permalink)
It shows like that only bro....
trying writing a dvd and then tell me...
PKG
Old 05-10-2008, 09:35 AM   #5 (permalink)
k let me try will tell within 10 minutes
AYmn is offline
Old 05-10-2008, 09:36 AM   #6 (permalink)
ok
PKG
Old 05-10-2008, 10:07 AM   #7 (permalink)
Bro burning process failed at 12x
AYmn is offline
Old 05-10-2008, 10:11 AM   #8 (permalink)
what then it might problem of the writer....
other wise its shown as you say
PKG
Old 05-10-2008, 10:14 AM   #9 (permalink)
no my writter is a new one AD 7200S
Burning process sucessfull
but still when i insert a balnk dvd it shows total size 0 free space 0 why is it so?
AYmn is offline
Old 05-10-2008, 10:21 AM   #10 (permalink)
looks like bad writer to me ..same things happened to me ..with my sony writer ...thrice after sending it to rashi for repair ..newer got alright ..bought a moserbear/liteon instead ..its working fine ..so far ..
chilling.....
imgame2 is offline
Old 05-10-2008, 10:22 AM   #11 (permalink)
no it is only showing Free space 0 and total size 0 but i can write balnk dvd with nero
AYmn is offline
Old 05-10-2008, 10:40 AM   #12 (permalink)
can u read them ?? whatever u write ???
chilling.....
imgame2 is offline
Old 05-10-2008, 11:24 AM   #13 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Sony drives with NEC/Optiarc hardware suck, like the one you have now. Get it replaced, and if possible, from another brand.
dheeraj_kumar is offline
Old 05-10-2008, 12:09 PM   #14 (permalink)
ya i can
AYmn is offline
Old 05-10-2008, 12:17 PM   #15 (permalink)
Violent serenity.
Psychosocial's Avatar
Get another one.......I bought a Sony Optiarc writer with my new PC and had to get it replaces the next day but the replaced writer (this on is Sony too) is working nice and fine but I dont expect too much from it. Get a LG H55n or LiteOn LH-20-A1P writer .
Psychosocial is offline
Old 05-10-2008, 02:01 PM   #16 (permalink)
ayush_chh's Avatar
a blank media shows 0 free and 0 total probably because there is no file system on it.....once u write some data on it gets a file system and then shows the actual data.......
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 05-10-2008, 07:53 PM   #17 (permalink)
Point Blanc
ok, my suggestion because I faced same problem wih my ASUS burner gives same solution, of replacing the burner. But for one thing Blank DVDs show zero space only. You can check it in nero express there is an option called Disc Info which gives size of the disc and free area info.
2nd comes DMA reset for burner if it taking very long to burn dics
burning at 16x time taken to burn is 6.5-7 minutes
12x in 8.5-10 minutes
8x 13-16 minutes
These are normal timings compare with your timings
3rd is a precaution you need to take while burning DVDs, while burning a DVD it is recommended not to do anything else, it can cause problems which you are getting.
Multi-tasking should be avoided while burning discs. People will say no it does not effects, that is why I am telling this beforehand that this does.
acewin is offline
Old 06-10-2008, 12:16 AM   #18 (permalink)
if i read correctly..
you burn then fail
you burn then succeed..fine
you can read what you burnt..fine
then there are no issue...
and as said above..it is just the way it is supposed to be.
realdan is offline
Old 06-10-2008, 10:36 AM   #19 (permalink)
static_x's Avatar
what i suggest is to get your writer replaced....beware of Sony DVD writes...I bought a sony DVD writer in 2005 and i replace it thrice under the warranty and finally dumped it...now using Samsung without a single problem
static_x is offline
Old 06-10-2008, 12:37 PM   #20 (permalink)
Daydream Believer
Ross's Avatar
It does read games pre recoreded DVD's ie Films, it reads dvd burnt on other machines and it reads all sorts of CD's. Wen i insert a a blank DVD of any kind the drive instantly turns from a DVD RAM into a cd drive on My computer. Any help anyone could suggest would be great and it show's Free space 0 and total size 0 my dvd writter is sony ad 7200s
Do you another CD or DVD writer in your PC..??
Ross is offline
Old 07-10-2008, 08:07 PM   #21 (permalink)
ya i have
AYmn is offline
Old 07-10-2008, 11:06 PM   #22 (permalink)
Daydream Believer
Ross's Avatar
ok,
this is sort of bug in XP, when you have 2 optical drives.
Did you also get error "Incorrect Function" when you insert a blank CD/DVD and click on it????
The workaround is, 'right click' on that drive's icon go to "Recording" tab and check "Enable CD recording on this drive". (let the drive be automatically be selected, but you can change it if you wish).
Now this drive will show correct size of the disc inserted .
(but, at the same time, now(surprisingly!!) your other drive wont , thats why i call it as a bug )
Ross is offline
Old 08-10-2008, 05:46 AM   #23 (permalink)
Even I have a Sony DVD RW drive with the same problem as AYmn. it is the only single optical drive. I was not at home for last 2 years and nobody noticed the problem as no one else really use that machine. Any way now am totaly screwed. Since the Sony does not have any drivers for its DVD drives there is no software patch which can solve the problem. Never to sony again for any drives .
JimmyJ is offline
Old 08-10-2008, 09:59 AM   #24 (permalink)
^^ liggydee.cdfreaks.com
You can get firmwares from there. Both original and modified.
Old 08-10-2008, 11:30 AM   #25 (permalink)
I tried but still it's showing the same.......
AYmn is offline
Old 08-10-2008, 12:37 PM   #26 (permalink)
Get drive replaced. No other solution.
Sony Dvd-writer churning out blank dvd's after burning......pls help tango_cash Hardware Q&A 10 08-10-2008 05:51 AM
Ram recognizing error yrana2002 QnA (read only) 7 24-09-2008 07:42 PM
dvd writer not workin properly. it gives blank dvd's after burning. tango_cash Hardware Q&A 7 07-06-2007 03:06 PM
cd not recognizing data .. alib_i QnA (read only) 11 17-08-2004 09:08 PM
- by kool
