Old 04-10-2008, 03:45 PM   #1 (permalink)
Default How much O.C. should I expect?
My friend has bought the following config:
Intel Q9550
Asus P5Q-Pro
Corsair 2 GB Dominator (1066 MHz)
Palit Ati 4850
WD 640 GB x 2 (set in RAID 0)
CoolerMaster Extreme 600W
Cooler Master Elite 333 Cabinet
He now wants to O.C. his system to a limit where he doesn't have to invest in a new CPU cooler or PSU. How much O.C. should he expect? He is also bit confused looking at all the BIOS options in the MoBo. If someone has worked on this then the input would be highly appreciated.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline
Old 04-10-2008, 03:49 PM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: How much O.C. should I expect?
Intel Q9550
Asus P5Q-Pro
Palit Ati 4850
Just a lil bit upon normal clock speed...Coz OC to extreme clock speeds need a aftermarket CPU cooler... So if he has 2.53GHz speed, it safe to stop by 2.8GHZ....(Even i worry for that)
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Old 04-10-2008, 09:34 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
3Ghz easily...stock cooling bah..If u'd hav checked this tread once u'd hav gotten n insight to Q9550's OCing power
Official OVERCLOCKKER'S
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 04-10-2008, 10:21 PM   #4 (permalink)
Point Blanc
BTW your friend has bought a monster rig.
acewin is offline
Old 04-10-2008, 11:28 PM   #5 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Try setting FSB to 375 which would give a CPU speed of 3.18 Ghz which can be acheived on stock cooling since its 45nm based and try setting ur FSB : DRAM ratio to 4:3 or 3:2 by changing ur DRAM Clock but don't exceed 1066Mhz on stock voltage.
At least the above is expected!
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 05-10-2008, 12:01 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Tell him don't go further than ~3.2GHz and be happy with his already powerpacked rig...
About me:
OpenOffice.org 3.0: What to Expect? Cyrus_the_virus Technology News 41 13-07-2008 11:01 PM
What do you expect most from XP SP3? young_joz Software Q&A 8 21-12-2007 05:09 PM
wat can we expect frm vodafone?? iinfi Mobiles and Tablets 20 19-02-2007 03:25 PM
how much kbps to expect Saharika Software Q&A 2 18-01-2007 08:10 PM
What can you expect on Fedora Core 5 ? desertwind Open Source 13 17-12-2005 05:01 PM
- by kool
